Instaled led lights on rear of truck turn singales flash rapidly
SOURCE: rear flasher not working front flasher flashing rapidly
with the blinker on hold the socket in your hand and wiggle on the bulb and see if it starts to blink. if so then you have a bad socket that needs replaced or sometimes can be cleaned and apply electrical grease. if you cant get the bulb to blink then get in vehicle and watch the signl indacator while putting pressure on the selector in which ever direction your having problems with. if you get it to work properly by doing this then you will need a new switch .
SOURCE: where is the turn single flasher on the 1997
The turn signal flasher is located just to the left of the accessory and lighter plugs.It is a black box.It includes the seat belt and ignition key alarm,flasher,and turn signals.Hope this helps.Good luck.
SOURCE: 2002 Durango Turn Signal Problems. A week ago I
.. Hi there.
This is a typical earth problem. Some of the lights use the same earth and when some of the earth points are not good, the power go through the other lights. That is why some lights go's faster, it's all about resistants. Check all the earth points in the light holders and under the dash and also between the battery, engine and body. Good luck.
