SOURCE: 1999 jeep grand cherokee / 4.0 L.
I had a skim module go out in mine in the ignition, and I have a 2001. It's a 100 part, and now it starts fine.
SOURCE: 98 jeep wrangler headlights wont turn on
I would check your headlight relay switch that is located in your steering colum
SOURCE: 89 Jeep Comanche Fuel Pump. Won't start after running great.
Replace the crankshaft position sensor
SOURCE: 2006 Jeep Wrangler won't start
First, make sure you can turn the engine by hand. If you can't then the starter can't turn it either. Have someone else turn the key and look for the source of the click...may be a relay. Go over the starting circuit with a volt meter. Check for power at the starter main terminal and then with the key turned to "start" check for power at the trigger terminal on the starter. Check battery voltage and check relay operation.
You have a neutral safety switch on the transmission if its an automatic and a clutch switch if it's a stick. Check them as well. Make sure battery grounding on fender and block are also clean and secure.
Testimonial: "Will try! Thanks!"
SOURCE: My 98 jeep grand cherokee wont start.
fuse 8 40a supplies power to starter relay and ignition switch, to close the starter solenoid and engage the starter which draws directly from the battery. check to see that the starter relay is closing, if not ensure that the park neutral switch is not faulty (open circuit), it provides path to close relay (ground side) on the 85 - 86 terminals. if the starter relay does not close the starter will not run. if you have a spare relay swap out the relay for a quick fix attempt. hope this helps
