Sony Mex-bt4000p Cd/mp3/wma Am/fm/ Bluetooth/ Sirius Xm Compatible Logo
Posted on Jun 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stereo wiring how to wire stereo wires to 2004 silverado wires
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Jun 04, 2012
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3737807
Points
36075
12volt dot com or installer dot com will have your diagram for free
2004 Chevy Silverado 1500 with Bose radio wire colors and what they do?
https://www.modifiedlife.com/2004-chevrolet-silverado-stereo-wire-diagram/
Color meaning on 2004 Chevy LS 2500 radio wiring harness
2004 Chevrolet Silverado March 31st, 2012
Posted in Chevrolet Silverado
2004 Chevrolet Silverado Stereo Wiring Information
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Class 2 Serial Data
Radio Ground Wire: Black/White
Radio Amplifier Trigger Wire: Pink
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
2004 Chevrolet Silverado Speaker Sizes
Audio Front Speakers Size: 6.5?
Back Speakers Size: 4? x 6?
The following information is currently not available:
Radio Illumination Dimmer Wire
Radio Antenna Trigger Wire
Front Speakers Size
Rear Speakers Size
https://www.google.com/search?q=2004+Chevy+LS+2500+radio+wiring
What colors go together in 2004 Chevy Silverado truck when hooking up a stereo t in truck
limited info generic answer this is for a base silverado https://www.modifiedlife.com/2004-chevrolet-silverado-stereo-wire-diagram/
Step by step instructions on how to wire my pioneer avt 290bt stereo to my 2004 silverado chevy
If factory wiring still has plug you should buy the harness kit. It will be color coded.
I need to know the wire diagram for my 04 Silverado crew cab. Previous owner removed the original stereo and put a horrible after market stereo. Now I want to replace that with a after market stereo can...
use a test light and a battery. the black is ground, orange is constant and yellow is your turn on and off (ignition). then take a 9volt battery to check your speaker wires. front should be green and light green and gray and light gray. double check it has ben a while, rear is blue and light blue, a yellow and brown. you do not need any other wires in the harness unless you are using a power antenna or amp which you can use the yellow wire for ignition. double check with test light and 9volt battery. the 9volt battery will make the speaker pop noise, you then know you have a speaker when it makes that noise.
2helpful
Wiring for a 2004 trailblazer stereo
Here are the factory wire colors.
2004 Chevrolet Trailblazer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Installing aftermarket stereo in 99 silverado which wires from stock harness connest to aftermarket harness
connect the wires as indicated below
1999 Chevrolet Silverado C1500 Wiring, aftermarket stereo wire colors
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (Tape off) not used
Car Stereo Dimmer Wire: Brown (Tape off) not used
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
6helpful
2answers
Looking for a diagram/schematic for the stereo wiring, so i can reinstall my new cd/stereo player
I hope this would help you: 1999 Chevrolet Silverado C1500 Car Stereo Wiring Diagram
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
