. When you open the door or just unlock the door the lights don't come on ?
Vehicle Security Module
The vehicle security module receives inputs from the following:
- door ajar switches
- keyless entry keypad
- ignition switch
- remote keyless entry transmitter
The vehicle security module uses these inputs to control an output signal to the instrument cluster which controls the battery saver relay and courtesy lamp output.
Interior Lighting Systems
The instrument cluster grounds the battery saver relay and supplies the power for courtesy lamps when any door ajar switch is opened, or the interior lamp (headlamp) switch is closed. The instrument cluster then supplies voltage to the interior lamp circuit. Vehicle speed must be less than 24 kph (15 mph) for the instrument cluster module to keep courtesy lamps on. The interior lamps will remain illuminated for up to 25 seconds after all doors are closed unless the instrument cluster module receives an input from any of the following:
- voltage from the ignition switch
- a vehicle speed signal
- input from the keyless entry keypad through the vehicle security module
- input from the remote keyless entry transmitter lock or panic switch through the vehicle security module
Do you know what body control system DTC'S - diagnostic trouble codes are ?
Instrument Cluster Diagnostic Trouble Code Index
DTC
Description
Source
Action
B1342
ECU is Defective
Instrument Cluster
REFER to Section 413-01 .
B2499
Courtesy Lamp Output Failure
Instrument Cluster
Go To Pinpoint Test A .
B1320
Driver Door Ajar Circuit Open
Instrument Cluster
B1328
Passenger Door Ajar Circuit Open
Instrument Cluster
All Other DTCs
Instrument Cluster
REFER to Section 419-10 .
Principles of Operation
The autolamp system provides light-sensitive automatic on/off control of the headlamps and parking lamps controlled by the vehicle security module when the headlamp switch is in the autolamps position. When the ignition switch is turned to the RUN or START position with the autolamps feature already enabled and the ambient light level is dark, the vehicle security module will request the headlamps and parking lamps be turned on. When the autolamps are disabled, the vehicle security module will request the headlamps and parking lamps to be turned off, regardless of the ignition switch position. When the vehicle security module has turned on the exterior lamps and the ignition is turned to the OFF or ACCY position, the exterior lamps will remain on for an additional time specified by the customer or the headlamp switch is turned off.
When the autolamps have been enabled and the ignition switch is in the RUN/START position, the vehicle security module will request that the exterior lamps be turned on or off based on ambient light level. If the vehicle enters darkness for at least 15 seconds, the vehicle security module will request the exterior lamps on. If the vehicle enters light for at least 15 seconds, the vehicle security module will request the exterior lamps off. By delaying turning on and off the exterior lamps during short periods of darkness and light, the vehicle security module prevents the exterior lamps from flashing on and off.
- The autolamps are inoperative - do not operate correctly
- Circuitry.
- Photocell.
- Headlamp switch.
- Vehicle security module.
Power Lock
The power lock/unlock feature requests all of the vehicle doors, including the liftgate, be locked or unlocked upon a customer request from any interior door lock switch in the vehicle. The power door locking system functions independently of ignition status or vehicle speed. When the vehicle security module receives an unlock/lock command from any door lock control switch, the vehicle security module will activate relays internal to the module to supply the correct power and grounds for the door lock actuators.
Your best bet , take it to a qualified repair shop .
the changes are not available on this model.....can the parameters be changed by connection to a dianostic tool?
