Peavey Pv 2600 Power Amplifier Logo
Posted on May 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Volume ports voloume pots
Power Electronics
Level 2:
Champion:
  • Expert 243 Answers
  • Posted on Nov 05, 2013
Power Electronics
Expert
Level 2:
Champion:
Answers
243
Questions
Helped
61714
Points
270
It maybe the pots but i strongly recommend that first clean all back switches including the Bridge/Stereo switch which it has to be outwards to stereo listening, then let me know your results to help you out more.
Low volume one speaker
It seems likely that the pot (volume control) is dirty. with a slider you can normally get fluid down the side of the knob, your's is a rotary control and you sometimes can do it round the shaft of the pot but more often have to spray it in where the connections go into the pot. You'll need some contact cleaner spray which you can get online or from an electronics store, get it onto the pot track and then take the pot to each end of its travel a few times, this'll probably sort it out until next time. If you're taking it apart it might be worth just getting a new and better pot and soldering that in if you are hand with a soldering iron. The ones in Mackies nowdays are pretty sh1t.
How to clean volume pot on a rmx5050
Just spray a few shots but you have to take the top cover apart, then take out 3 philips screws in the pots module, take off caps and then you should be able to give'em a good cleaning spray shots.
I nned mxr fullbore pots replacements
Usually with volume pots,the ratings dont matter. you can really buy then anywhere like guitar center,micro center and online. they're really cheap and well worth it.
When I use the Master volume the amp will suddenly bypass the master volume. And when I play on the top boost the volume fluctuates by itself. Thanks for your help Devon
I suspect you may have either a circuit board crack or the volume pot is bad or soldering of it is bad. Vibration will make things come and go. Look for broken solder around the pot leads first. Then look for a cracked circuit trace on the board near the ground end of the volume pot. If you put cleaner in the pots NEVER use Deoxit or Blue Shower. Use CRC226 which is available at Home Depot in the electrical dept.
Problems with tone pot and volume only works at full volume
Pots are dirty or worn. Use an electrical control cleaner made for volume controls or have them replaced.
On my squier strat the volume doesnt come out through theamp at all[i know it's not the amp or cable cuz i've hooked others things up to it to make sure]. Everytime i push and hold the volume knob at 10...
It is not clear if the volume knob you are talking about is in the amp or the guitar... SINCE you said you verified the amp is OK I have to assume the volume control you are talking about is in the guitar and my answer is based on that...
I SUSPECT that the resistance element and/or the wiper in the volume pot is damaged. One other possibility is the soldering of a wire to the volume pot may be bad. If you are competent with a soldering iron you could replace the pot yourself or take it to a competent guitar shop for repair. I would myself suggest you open the electronics and look for anything obviously wrong. I have ALSO seen one other problem where one lead of a pot is touching the CONDUCTIVE paint in the cavity where the controls are. If the shaft nut becomes loose and the pot slightly rotates this can happen, grounding out the signal.
Replacing the volume pot on a Gibson ES335.The best method for getting the old pot out of the guitar to enable it to be unsoldered and the new item to be soldered in it's place and put back into the...
If the volume pot is scratchy noisy, FIRST try squirting a bit of CRC226 into the pot. CRC226 is available at Home Depot in the electrical department. There are other CRC products there so be sure to get the 226 type. About $2.75 a can.
The product is also good to use in slide pots on mixers. Use sparingly, it doesn't take much. For rotary pots you often can use the spout to spray into the slot where the terminals go into the pot.
1helpful
3answers
I have a fender guitar amplifier, and I can't get any low volume out of it. At level 1 on the dial the volume is sooo loud - no gradual increase at all. It's impossible to play softly. What's going on?
It sounds like (pun intended) the volume pot just needs to be replaced. A good pot is worth about $5 and then you just need to solder it in. That tends to be the tricky part if you can't solder. It takes longer to heat up the iron than it does to do the job. I'd assume this happened either after it had sat for quite a while or after a move.
What can happen is the wiper or the resist inside the pot breaksor even the wire to the pot breaks and there goes your volume control. Depending on what model of amp you have you don't want to run it like this for too long. You can't fix the pot but you do need to replace it. I would assume it sounds like it is either full on or doesn't change the volume at all.
This is one of those maintenance things you should check for from time to time. you may notice that the pots get noisy or inconsistent for a while and then they do this kind of thing.
The attenuator will kill the volume but that doesn't actually fix the problem you have. When the amp is running properly you should be able to get quite a low volume. If you need to run it harder so that it gets into the distortion range then a attenuator will drop the volume down to a practice at home non eviction volume ;-]
May 03, 2010 • Music
1helpful
2answers
I have a Fender Hot Rod Deluxe. It has very few
First try turning the volume control down before turning switch to operate.
IF this seems to fix it, IF the unit has a tank reverb, the vibration of the reverb springs MAY be causing the problem. The solution then is to reduce the volume before applying power WHICH is a good idea anyway... from an electrical engineer.
Problem with volume dials in an electric guitar.
If you can't clean the pots or if you just want to try replacing them, try using
500k pots again, in case one or both of the pots is worn or dirty or
defective. If that doesn't work, and cleaning or replacing the
switches doesn't work, then the problem is probably elsewhere.
You could put a 500k resistor (with a sufficiently-high power rating of at least half the power rating (Watts) of the pot) in parallel with the pot, or, to cover all bases, put a 500k resistor from each of the two outer lugs of the pot to the middle lug. That should change it into the equivalent of a 250k pot. You could even just temporarily clip the resistors on, with alligator-clip leads, if you're very careful, just to test it.
Good luck,
The dude.
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
