Can anyone have diagram how to fit this timing chain for this ford courier v6 4.0 lt plz
SOURCE: 2001 Ford Ranger V6 timing chain
Hello;
The Ford motors are pretty good. I had 280K on a 2.9 V-8 that only needed the oil changed every 3K. Unless you have fluctuatuation in the timing then you should be ok.
These engines use a chain rather than a belt and have excellent life.
Thanks;
Rich RPM Northwest
SOURCE: need to put a timing chain back on a ford taurus
Heres a diagram showing you how to line it all up, good luck and hope this helps,note there are two types of engines in this car with the 3.0engine i labeled them one is a push rod engine which is the simple chain setup, then then overhead cam engine this is the one with chains going to both heads, good luck hope this helps, also if your not sure count the vin digits from left to right the 8th digit is the engine vin # i list them on the diagrams,
SOURCE: diagrams for timing chain for ford f150 2005
if you did not set a code then the timing is not off. Use a data scanner to check it. What makes you think the timing is off ??
