Anonymous Posted on May 22, 2012
ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I recently bought an ION Profile Vinyl-to-MP3 Turntable. Pretty inexpensive player but gets the job done for what I need. It worked well for the first dozen records but now the tone arm absolutely refuses to drop onto the record. Every time I move it, it automatically returns. I've tried moving it fast, slow, have changed the angle with which I approach the record, have done things like removing the USB cord, balancing the player on different surfaces, all with no luck. I'm hoping not to have to send/bring this in for repairs, since that would likely cost more than what I paid for the player. If someone could give me some basics on how the auto-return on a tone arm works I will try to fix it myself.
  • 1 more comment
  • Anonymous May 23, 2012
    Thanks Michael, that was an awesome suggestion and I'm now back in business. To clarify, what I'm doing now is spinning the turntable counterclockwise about 3-4 times before I try to drop the tonearm. Here's something else that future people with this problem might try ... this was what ION's support told me to do. This did not seem to work but between this and Michael's suggestion, I was on the right track.
    "Push the stop button and manually rotate the table about 90 degrees, then release the button and complete a single rotation of the table, and it *should* reset it.
    Holding the stop button should reset the armature so that it'll run through a record once, at which point the armature *should* reset."
    Again, this didn't work for me, but maybe it will work for others.
  • Anonymous Aug 17, 2012
    I have to rotate the platter about 12 times counterclockwise (without the stop button part) every time I want to record a record.
  • Anonymous Feb 25, 2013
    Thanks for the tip! I've just tried the ION's tip (pressing the stop button etc.), and it worked perfectly again!
Michael
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on May 22, 2012
Michael
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
34358
Points
317
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 29, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2205
Points
0
I'm having the same problem, the tone arm keeps hanging above the vinyl. If I take the counterweight off mine, the needle will touch the vinyl, but I feel like there is too much pressure. I couldn't find anything else on the net - I'm am using a Stanton t 120 C curve arm DJ turntable - please help.
2 Related Answers
Anonymous
  • 515 Answers
  • Posted on Sep 08, 2008
SOURCE: Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Anonymous
  • 19 Answers
  • Posted on Dec 23, 2009
SOURCE: My Ion vinyl TTUSB turntable is extremely slow in
Upload the newest ION software-Itunes updated to 9 and something went flukey. That should take of it. http://www.ionaudio.com/ionttusb
How to connect ion turntable to bose radio?
Why whole you try to connect a computer accessories to an audio system? Even when both things are made for audio.
To bring digitising vinyl, closer to the computer user, ION produces record players, which don't output audio signals, but digital signals.
The digital signals can be read by a computer, when connected to a computer with the appropriate software installed.
If you want to connect the record player to an audio system, you need to rip it down. Trow out the digital part, and connecting correct cabling, straight to the cable coming form the PU element. Then you will be surprised, how little modern amplifies still can handle the low signal levels a PU element produces.
I'm sorry I have to say you can't use the ION turntable in a normal audio system, like you can connect any USB connector to a normal audio amplifier, unless you modify the whole system. And if you would modify, the sound coming form that system, would sound poor, considering what you have to pay for the ION, and the modification. A normal record player, with a correct pre amplifier that can be connected to the Bose, would be cheaper.
Ion turntable
Could be, but check the wiring to the cartridge, plus the connection to your amp. A poor earth wire or one touching the other can make it sound tinny.
1helpful
2answers
DOWNLOADING VIINYL LP'S TO MY COMPUTER USING
opening the file from audacity you made from the vinyl? are you making them .wav or .mp3 files. If not I sugguest you do . Much easier!
Im trying to sinc my 4th gen ipod touch through an ion iprofile record player, is there a way i can do this?
No, unfortunately the device was only meant for LP to iPod or LP to computer type connections, and doesn't support normal itunes syncing.
Hello, Does anyone know how to take the platter of an Ion Profile LP?
YOU MUST UNLOCK THE INSIDE AND THE TOP LOCKING RIGHT ... IT IS VERY SMALL TO SEE. IT IS THE ONE HOLDING IT ON TOP.. JUST TAKE IT OF THE CENTER PIECE. IF YOU HAVE TROUBLE..GET THE MANUAL AT WWW.TVPARTSANDMANUALS.COM AND FOLLOW INSTRUCTIONS
1helpful
2answers
Sound quality
Did you make the audio changes in the Windows Control panel documented in the Ez Vinyl 4.1 Setup Instructions? You must set audio format and levels to specified levels for Windows 7.
1helpful
Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
 Grubhead
Grubhead
SmartAviator
SmartAviator
