I brought a second hand Einhell Wall Chaser BMF-1300. It runs at slow speed at around 20%. It does get up to full speed after pulling the trigger and number of times, can take minutes to do this. I can't figure out why it gets to full speed. I have checked for loose wires and replaced with new brushers.
Check if the running belt is lubricated. You can't run an engine without oil. So, spray a good quality silicone lubricant on the base of the running belt. It is best if you spray on a lint free cloth just enough to make a wet patch. Do it outside so that no spray residue lands on the floor and becomes slippery or lands on the carpet and stains it, then return inside and lift the treadmill running belt and soak or smear the base with the wet patch of the cloth and run for a full minute. Then lift the belt again and give it another swipe on the entire base, then feel the base with your fingers or hand to see if it feels wet and smooth. Run the treadmill for another minute at slow speed, otherwise the liquid can fly and splatter on wall or floor. If it still hasn't solved the problem, then it must be the motor brushes, or it may be set to run slow and fast according to the running settings on the console. Mine does the same thing if it is programmed to do 1 minute slow and one minute a bit faster. Good luck.
i have two one completely stoped but my other had ur same problem i took it apart and oiled it with wd40 theres two motors oil them both amazing that this was all it needed and it still works i love this fan but its is dicountinued good luck
Simply plug the ac adapter into the wall, the laptop will charge the battery itself.
Keep in mind this... in general, a laptop runs at full speed when it is plugged into the wall. When most laptops are running on battery, things are running more at 50% capacity to save on power, this giving you more battery life. A dimmer lcd and slowing the processor down when not needed are common traits.
You can use the FN key (function key) and the corresponding dim control on the keyboard to adjust the brightnedd of the backlight. It should be marked on your keyboard in a different color, like blue or maybe green (not familiar with that models keyboard).
