Is there another nut somewhere to hold while I turn the one on the blade?
SOURCE: craftsman lt 2000, blade not staying in place
i would need a complete sears model number to look this up for you, however, you will need to remove the intire blade spindle housing, then you can remove just the shaft from the housing. and just replace the shaft. Will save a lt of money.
if you can find the complete model number you can go on the internet to
mtd.com/parts or to ayp.com/parts
and you can pull up a parts diagram and find the exact part number and order it online, or take model number to sears and they will either have it in stock or can order it for you. Sears will however cost you a fair amount more then ordering online. I hope this helps you
SOURCE: my mower vibrates badly when
there should be like three or four bolts the have to come off and the pulley comes off the deck and then all you need to do is take it to a small engine repair shop, or order the part off line. Hope this helped Tim
SOURCE: I have a 17hp Craftsman
impact gun is the easiest way, if not the you will need to use a pipe wrench and a ratchet. Hope this helped Tim
