E20 error code: Short or break causing incorrect resistance in winding of the circulation pump or the motor.
D10 error code: Cause: Wiring/electrical fault related to motor triac.
Action: Check wiring on/to PCB and motor. Check the triac (on the PCB).
C01 error code: Cause: Motor tacho fault.
Action: Check motor and motor tacho wiring for problems.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
is this correct? it doesnt work for c&w london
