I bought the car used and no key fob came with it
Hello! There is a Service Parts Identification sticker located either in the glove box or near the spare tire with a list of three alphanumeric codes...If the sticker has "AP3" that means your Buick has remote start...
Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
SOURCE: My remote won't start my 2005 Buick LaCross. I
Both my remotes no longer work. I will be ordering new ones off Ebay and having my dealer program them. New ones from Buick are very pricey.
SOURCE: remote for buick Lacross doesn't work, battery new. Can't figure how to reset it.
have to be reset by dealer usually 20 to 35 dollars to do so
SOURCE: programing instructions for buick 2006 lacrossekeyless remote fob
Transmitter ProgrammingImportant:
All transmitters which are to be recognized by the remote control door
lock receiver (RCDLR) must be programmed in a single programming
sequence. If the system is placed in program mode it will erase all
previously programmed transmitters upon the receipt of the programming
signal from the first transmitter. Up to 4 transmitters can be
programmed. Do not operate or program the transmitters in the vicinity
of other vehicles that are in the keyless entry program mode. This
prevents the programming of the transmitters to the incorrect vehicle.
Good luck
SOURCE: hood will not open when you pull release handle
There might be several problems:
1. Cabling to and from handle and latch is loose or stretched (normal wear) or broken. Replace and/or adjust
2. The latch is dirty or bent/deformed. Clean and lubricate
3. The latch needs adjusting, lubricating. Clean and lubricate
4. Misalignment of hood due to: wear, or slight bump/accident, nudge. Check for alighnment!
Try having someone pull up the hood while you pull the lever. This is a quickie only; then do items mentioned above...
SOURCE: how to install/change complete headlight assembly
Buick Lacrosse - The bright light fitting is the same as the dim so take it apart first to see how the cover screws off/on and the light comes out. Both the cover and the bulb are removed by a standard twist to the counterclockwise and replaced by a twist to the clockwise. Now to the dim light. You have to release the entire light assembly before you can remove the screw-on cover to reach the light. On the rear edge of the light unit closest to the engine is a white locking tab. Pull that tab up just to the point where it releases…pull too far and it locks again. Next, locate the other locking bracket which is a metal bracket in the center-rear of the light assembly. This bracket is held down by a screw. Remove the screw with a 10mm wrench. Lift the bracket just like you did the white bracket. You should now be able to pull (or pry) the entire light unit forward a little. Depending on the size of your hands this might be enough. If not, then you need to release the plastic bumper assembly to give you a little more space. This is done by removing two expansion locking pins, one that holds the little plastic strip down between the bright and dim lights and one that is located inside a rubber bumper on the engine side of the light unit. To remove these locking pins, pull or pry up the little tab in the center of the pin just like you were pulling a nail by the head. That should give you more space.
