Left tire with sharp turn hits cutting deck. Looks like crossover brace is split . what is the brace called that attaches to the from for front end steering and mounting of tires Can this bar be repaired or replaced?
SOURCE: JD 2030 power steering failure
either the steering arm in the bell housing on the right side of the tractor is striped or the colume is broken internaly. the is asuming that all tie rod ends and the bell crank are still atatched.
SOURCE: Steering, The right front axle
1) there are also bushings which hold the axle assembly into the front cross member, take a look at those.
2) while you are at it, replace the front wheel bearings on both sides
