Starts fine but just bogs down under acelleration
SOURCE: 99 escort sputters and stalls, engine bogs down in idle
The CAMshaft position sensor is faulty.
SOURCE: 1997 Ford windstar Low power and very poor
35 is low fuel pressure, should be around 40-44 PSI and 46-50 PSI under a load, replace the fuel filter it may be clogged.
SOURCE: 1998 Ford F-150 4.2 V6 starts and idles fine ibut bogs when step
i had a van do this same thing to a tee turned out to be a broken key pin in the harmonic balencer causing the timing to ****** replaced balencer and ran like a dream there is a crank sensor grid on the balencer when the key pin broke it trew the timing off
