It stops in middle of cycle , it seems after it does a drain, then the blue light flashes on the kick plate and it makes an annoying clicking sound and it cannot be stopped unless we turn the power off at the breaker. we plug again, it starts again and it does the same thing , stops, flashes and chirps non stop. we cannot reset ..Help!!!
SOURCE: cycle control lights flashing all at same time
are you sure you have cleaned all the water outlets as when these get blocked and the water builds up the dishwash will go into a standby mode as a sefety precaution to stop your kitchen getting flooded if it was me i would take off all water outlet pipes and use boiling water and a good cleaning fluid it only takes a little blockage and then it will cut off so clean all pipes through properly and then try again is the water going into the dish washer before it cuts off or is their no water going into it either if you post back ill have a nother look for you hope this is some help i had same prob with mine but it was different brand of washer but after cleaning all pipes inlet and outlet it worked fine and is still working now use good limescale remover cause if you live in hard water area then this is probably you problem .......................................................
SOURCE: Viking Dishwasher Leaks Into Base
Since this was posted in May I guess it's been fixed but for those of you seeing this problem for the first time, here's one reply:
This sounds exactly like the problem I just found with my DFUD042. There is a small black hose between the base of the tub and a pump motor - part number on the hose is 8072888. The hose has a small **** or crack in it and water is leaking which is most likely the problem causing the symptoms. I had to throw the circuit breaker to get mine to shut off as well.
When I tried to remove the plate it was stuck under the black sound proofing so I had to work around it a bit until it finally came off. Now I just have to find the hose and some clamps.
SOURCE: Dishwasher will not start
you can hold the start atop button down for 5 seconds to re set it or you can turn off the circuit breaker to the dishwasher for 20 sec. That should help. If not, it probably is a bad celenoid which a repairman needs to replace
SOURCE: Viking dish washer won't drain
Try clearing the air gap (which is the seemingly pointless thing that is near your kitchen faucet.)
1.Take off the shiny metal cover, and you can sometimes twist off the plastic cap, or you may need to use needle nose pliers to push in the tabs that hold it in. You may or may not see debris in the tube that is in the air-gap.
2. Now what you need to do is take a clear glass and put it over the air-gap with part of the glass hanging over the edge of the sink, you may want to put a towel around the other side of the glass to keep the water from going all over the counter, turn the dishwasher off then on again and select "rinse and hold". If there is any thing in the line it will come out.
3.If not you may need to take out the filter in the bottom of the dishwasher and on the left hand side in the sump area there is a small, (usually yellow) cap that covers the drain motor impeller that can usually be pulled towards the center/right by hand, if not with needle nose pliers. You will need to vacuum out the water with a wet/dry vacuum or towels.
If none of this works, let me know and I will go over some more uncommon draining problems.
SOURCE: Viking dishwasher that does not stop draining
I have the same thing, unit pump keeps running, when I pulled it from under the cabinet, if you tilt it back a little it stops, as soon as you lower it back down the pump starts to run again. Getting code as too much water in the tank even though it is empty. PLEASE HELP!!!!!
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
• Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
• The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
