Error 1297: A privilege that the service requires to function properly does not exist in service account configuration.
Click on Start-Run type services.msc the click on OK. When the Services window loads, navigate to the Windows Audio Service the double click on it to open it. Make sure the Startup Type says Automatic and started. Go to the Log on Tab and make sure that the Local System account option is selected along with the 'Allow service to interact with desktop' box. if this fails to fix the problem if your computer came with a motherboard disc the sound drivers could be on it click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If it doesnt use the drop down menu to change it.
reinstall drivers
hope this helps you
Windows 7 is the latest operating systems acquirable on computers. Once acquired, there will no need for any codes or program updates with new computers already installed by the manufacturer. Computers acquired during the last couple years are windows 7 developed least expected to malfunction probably not yet has program codes available for repair purposes. If the windows 7 have started malfunctioning, contacting the technical support experts of the computers manufacture is appropriate to ascertain as may be a manufacturers default condition. Usually acquiring a new computer should be expected compatibility with available software codes. However, the latest designs are improvement over what exist and would least require an extract code programs for proper functionality like with older outdated computers. The windows 7 should be capable of performing functions in an alternate means only requiring familiarization by user to attain operationality. Sound error on new computer is an indication that the audio file attempting to play appears in an encoded format require decoder conversion. Multimedia programs have the capacity to achieve conversion of audio video formats however the entire program has to be acquired from retail to be installed onto the computer rather than the code or driver extract. While at retail remember to provide the associates with computer brands, manufactures specification since program software's are designed according to specification unique to each computer. The details of the computer would enable the appropriate compatible programs software to be acquired making available audio videos also known s multimedia conversion to repair the codes errors displayed during media applications.
sorry OS not motherboard
