Soon as i turn it on it goes back off
Older model---it should when you try to turn it on have the red light blink for several seconds (set is checking things inside) and if comes on and shuts off that light should blink a specific sequence of blinks----5 blinks and repeat it endlessly---
I have a stupid question: when it first failed did you hear a small pop or smell a faint odor of something burning?
SOURCE: Television powers up then shuts off Kp-53v35
You likely have an open fuse caused by bad convergence ouptut ic's type #STK392-560 sony part #8-749-014-67. There are 2 in the set and i recommend replacing both at the same time.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
SOURCE: Sony KP-51HW40 6 blinks
Hi Yeooow,
I guess you read the fix for my set wth the six-blink error. If not, here's the link:
http://www.fixya.com/support/t647530-tv_couldnt_turn_no_picture
My set is a KP-53HS30, chassis number P65A-A.
I found a bulged capacitor on the "G" power supply board and replaced the components associated with that circuit (6-volt regulator). If your set has the P65A chassis, I'd be happy to e-mail you the service manual I have, if it will help.
-Dan
SOURCE: Sony 57" KP-57WS500 went from blue to black screen, with audio
you need a new Blue CRT you can get one for around 300 at the following link.
http://servicemanuals.vstore.ca/
SOURCE: No image on sony rear projection tv (model KP-53V35) for 20 minut
sony has a circuit than balances the 3 crt's. it needs a screen adjustment which is located in the front of tv behind speaker grill. easy repair
