Nikon Action Zoom XL (10-22x50) Binocular Logo
Posted on Nov 06, 2008
Foggy binoculars My Binoculars got wet and now when I look through them it looks foggy
5 Related Answers
Anonymous
  • Posted on Oct 09, 2008
SOURCE: Leitz trinovid binoculars
I am trying to get Leitz binoculars repaired. Do you know where I can send them?
Ash
Anonymous
  • 112 Answers
  • Posted on Dec 22, 2008
SOURCE: Binoculars Stiff to focus
if they continue to get stiff then eventually the 3 set screws that hold the focus wheel loosen, and you will have no focus capability, its rare with zeiss but sounds like they should be regreased. the problem is to regrease you have to take completely apart as it is internal focus.if i can help any further contact me@ [email protected]
Anonymous
  • 26 Answers
  • Posted on Jun 28, 2009
SOURCE: My Bushnell Binoculars were left under the barn
take a large plastic bag, fill wth two inches of rice, place binoculars on top, seal bag and leave upright as not to get rice all over them, should work? gl [email protected]
Anonymous
  • 26 Answers
  • Posted on Jun 29, 2009
SOURCE: binoculars
don't know if they are worth repair as you didn't say wich model, have repaired many and sounds like a loose prism to me, if i can help further..15088331232
Anonymous
  • 112 Answers
  • Posted on Aug 13, 2009
SOURCE: My Nikon binoculars show two images
must have been dropped ...have to be realigned if you want i can supply estimate 15088331232 ...larry
Why do need a waterproof spotting scope?
Many activities that include the use of scopes such as binoculars, spotting scopes and riflescopes take place outdoors, often in damp, humid or foggy conditions. Having waterproof binoculars, spotting scopes or rifle scopes will eliminate your concerns about moisture damage, including fogged over inner optics that are sure to ruin your day out! Some waterproof binoculars can even withstand short submersion's in shallow water so even accidentally dropping them in a puddle on a hike won't matter.
Apr 16, 2018 • Optics
3answers
What are the strongest binoculars
Check this video out, i bet the North Korea president has strong ones,it shows him a lot looking thru him. The World Most Powerful Binoculars From Sunagor
Aug 16, 2017 • The Optics
I have a pair of Docter 7x42B and the left lens is foggy. do they have a gas in them? How do I get them fixed?
Binoculars are normally purged of all air and filled with nitrogen to prevent fogging and mould issues. If one side fogs internally it's a sign that a seal has leaked and needs to be replaced. The manufacture or any camera repair store should be able to replace the seal and refill the chamber with nitrogen.
Oct 29, 2013 • Optics
1helpful
I see double image unless I take the lens as close as the binoculars can go
thats how binoculars are. Yours in this case is really strong. the closer you are to something, looking at it, the more magiflyed you going to be. try view things far a distance, really far away. no more double right?
Everything you need to know to become an expert:
on this website: http://www.chuckhawks.com/binocular_basics.htm
It is surprising how many people do not know how to focus binoculars correctly. There are two common focusing systems used in binoculars.
The first is individual eyepiece focus. This system is simple to understand, and easy to manufacture. It also lends itself well to sealed optical tubes, and thus is usually the focusing system used for waterproof binoculars. Individual eyepiece focus means that to focus the binoculars to your eyes, you simply focus the left eyepiece to your left eye and the right eyepiece to your right eye. There is no centrally located focusing mechanism. It is done like this. Look at something in the distance. Close the right eye (or cover the front of the right binocular), and focus the left eyepiece to your left eye. Close the left eye (or cover the front of the left binocular), and focus the right eyepiece to your right eye. You are finished, until you need to look at something at a different distance, in which case you need to repeat the process.
Because individual eyepiece focus is time-consuming, center focus is more common. Unfortunately, very few people understand how to correctly use center focus binoculars. Here is how it is done. Aim your binoculars at something in the distance. Close the right eye (or cover the front of the right tube), and focus the left side of the binocular to your left eye using the center focus control, which is concentric with the pivot shaft between the binoculars. (Note: the left eyepiece itself does not focus on center focus binoculars.) Next, close your left eye (or cover the front of the left tube), and focus the right eyepiece to your right eye. DO NOT touch the center focus control while you are focusing the right eyepiece to your right eye. Now you are finished. What you have just done is adjust the binoculars for your individual eyes. (Practically everybody's left and right eyes are different.) From now on, you only need to adjust the center focus control when you look at things at different distances. Center focus is faster and easier to use than individual eyepiece focus, once you have initially set the binoculars for your eyes.
Binoculars are commonly described by using a pair of numbers, as in "7x50" or "8x25." The first of these numbers refers to the magnification offered by the binocular. Magnification is why most people buy a pair of binoculars. In the examples above, "7x" means the binocular makes whatever you look at appear seven times closer than it does to the unaided human eye. "8x" means the binocular makes whatever you look at eight times closer than the unaided human eye. "10x" makes things look ten times closer, and so on. The first number used to describe binoculars always refers to their magnification. Common binocular magnifications are 6x, 7x, 8x, 9x, and 10x.
There are also variable power (zoom) binoculars, such as 7-21x50. These almost always perform much better at the low power setting than they do at the higher settings. This is natural, since the front objective cannot enlarge to let in more light as the power is increased, so the view gets dimmer. At 7x, the 50mm front objective provides a 7.1mm exit pupil, but at 21x, the same front objective provides only a 2.38mm exit pupil. Also, the optical quality of a zoom binocular at any given power is inferior to that of a fixed power binocular of that power. In general, zoom binoculars are not the bargain they seem to be.
Remember that everything (including movement) is magnified when you look through a pair of binoculars, especially your own shakes and tremors. So the higher the power, the harder it seems to hold the binoculars steady. 6, 7, or 8 power binoculars are easier for most people, even those with very steady hands, to hold reasonably still. The higher powers sound like a good deal, but often result in jiggly, blurred views. This is why 7x binoculars are chosen by so many experts, including the military.
Power affects brightness. Other things being equal, the higher the power, the dimmer the view. And power also affects the field of view of the binoculars. Again, everything being equal, the higher the power, the smaller the field of view. So, as you can see, power must be balanced against other desirable characteristics when choosing binoculars.
Zeiss Deltrintem cleaning?
First look through the binoculars backwards keeping your face about a foot behind them. If you notice any fogginess as you look through then they will need to be taken to a service centre for repair. Your local camera shop may know of a repairman. I can advise for Australia, but not so much for the USA of Britain. In USA the one company I am aware of is Captain's Nautical Supplies in Seattle.
1helpful
My Bushnell Binoculars were left under the barn & it rained but they were not in the rain & now they are foggy or misty inside what can i do have not had them but couple of months.
Who made these marine binoculars?
Without seeing a picture it is difficult but there is hope. Most binoculars branded by companies other than the big three come from China. Namely the Kunming United Optics Corporation. Just type in United optics China into google. Have a look at the BC 6 in the compact binoculars section they may look like your ones. Not many 8x26 units are nitrogen filled so I'm guessing on this one. They have a support section and may be able to help.
Looking for someone in either tyne and wear or northumberland to repair my binoculars
In the UK Kay Optical have an enviable reputation for repairing all kinds of binoculars. They are highly regarded by binocular collectors. They have been in business for years and will except binoculars posted to them and will post back. Their website is
kayoptical.co.uk
Mar 24, 2009 • Optics
2helpful
Poor quality
My response to these always makes me sad. There is no way of getting good picture. These camera binoculars are neither good cameras or binoculars. They do neither well. The camera is just attached to the binoculars. What you see through the binoculars is not what the camera sees. The binoculars magnification is not the same as the lens in the camera. It is like holding a camera on top of a pair of binoculars. The camera will take a picture in the area approximate to where you are looking. Digital cameras have a sensor. The more megapixels the larger the sensor should be. Camera makers are now making compact cameras with huge megapixel capacity without increasing the sensor size. The result is worse looking pictures. Not much is different with the cameras attached to binoculars only the sensors are much worse quality than those on a stand alone digital camera.
Maybe not the solution you wanted buts its the truth. If you do want to take bird photos your best bet is a pair of binoculars on a tripod with a digital camera adaptor and camera attached. The camera adaptors that are made in China are not expensive and are copies of some of the high priced units out there. all the adaptor is is a bracket which attaches to a tripod which holds the camera to one of the binocular lenses. That way you see what the camera sees through the binoculars.
Scope
Try www.binocularservice.com !! Good people and about 10day turn around.
Top Nikon Optics Experts
john h
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Nikon Optic Expert? Answer questions, earn points and help others
