My grandsons gator stopped working in reverse and in the lower gear.It only works in the high gear? Where do I look
One of your motors is probably out, you'll have to remove the dump box, and then the top panel, this should give you access to the motors unplug one and then test the gears, then do vice versa with the other motor, might still be under warranty, if you can provide me the date code i can tell you if its still under warranty
SOURCE: replace parts on ride-on toys
The gearboxes for both hummers and peg perego gators are under the back seat.
If you hear a clicking noise It is definatly the gearbox on the gator. The hummer gearboxes sometimes come loose from the motors, so it may be as simple as tightning the motor gearbox.
Here is how you take the gearboxes out from the gator.
1. disconnect battery
2. take hinge pins out from the dump bed to access the green cover plate.
3. take a flathead screwdriver and pry around the plastic cover to expose the gearboxes.
4. take the rear wheels off and remove the rear axle.
remove the motor gearboxes (they are interchangeable)
5. install the new gearboxes making sure the wires are secure and the wheels are going in the correct direction.
6. put back together.
7. hook up battery and your good to go!
If you have any problems are questions you can contact these guys at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have a toll-free number and are very smart when it comes to these peg perego ride on toys.
SOURCE: Please let me know how I can change the rear tires
My Grandkids go through these wheels every few years.
They love their Gator.
You take the center black cap off and use a socket to remove the attachment on the axle.
Here is the replacement wheels
http://www.shopjandl.com/sarp8115kny.html
They can also help you with the repair, I call them all the time..very friendly people.
hope this helps
Testimonial: "Thank you so much for the info. "
SOURCE: battery is charged but car is still not working,
I have the switch go bad on the gas pedal. You can find a replacement here http://tigerimports.net/sunshop/
SOURCE: What is the market price
a used gator in good condition should at least bring $100-150. it mainly depends on how it has been treated and stored. if its clean, good gearboxes and not faded, i would put it on craigslist for $150. there is a lot of demand for those, ive sold them in really bad cosmetic shape but working for $50 and in great shape with good battery and charger for $200. take a good picture and try and find the charger, that will add $
SOURCE: where can i get a rubber tires for a Peg Perego
the whole tire would be difficult to replace with a rubber one, but you can put bmx tires on the plastic wheels and that will give much greater traction, but shorten the life of the gearboxes. here is a link to how to do it.
http://www.youtube.com/watch?v=AAySJVt6bys
it appears that only high gear works and no reverse and no low gear?
