We received the Keurig as a gift. Even when new, it would require that we prime it after brewing. It now requires it after every cup. Annoying! I am glad we kept our old pot as a back-up! Also, it does not dispense a full cup everytime. We were excited to receive the Keurig but, have been less than impressed. Help!
SOURCE: will not brew a full cup
there may be an adjustnent that allows more water to flow in the same ammount of brew time!
SOURCE: One cup brewer, says it is brewing, but the
If the brewer heats the water but it doen not dispense this is probably because air is trapped in the tubing of the water system.
To solve, use as air compresser with minimum pressure (20-25 psi) and force air through the system using an air nozzle that is long enough to reach into the hole into the area where you fill the water. Place your hand under the dispenser and ensure you can feel the air from the compressor coming through.
Once you clean out the lines, you should be good to go.
We have had our coffee maker sitting on our shelf "broken" for months now. We tried this last ditch effort before tossing the machine in the trash and low and behold it worked! :)
SOURCE: keurig does not brew the large cup of coffee, only
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
SOURCE: I received a Special Edition Keurig for Christmas.
I had a similar problem, I solved it by removing the K-Cup holder assembly, and pulling the small bottom piece off (it just pops off easily). From there you can access the "Exit Needle", which is where the coffed comes out and which is prone to getting clogged with grounds. Once you pull that bottom piece off you can run a paper clip or something up through the bottom of the needle and dislodge any clogs. This procedure was listed on page 13 of my manual and worked great!
SOURCE: My Keurig does not brew
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
';][-0
Keurig
heatman101
