It sounds like your belt may have broke or came lose best case scenario. worse case motor is bad.if you turn it on and you can hear the motor coming on its going to be the belt. take off back access panel and take a look . sometimes you can acess it under neath. hope this helps
go to whirlpool.com w/ your model number, and order belt when you get the belt the install instructions will be in there. typically you remove a few screws from the rear of the unit and access the belt. theres a tensioner that needs to be loosened, remove old belt and replace w/ new. hope this helps. please rate the review please accordingly. we did find the problem, in order to fix it thanks alot
how do i get access to change belt please its snapped ive got whirlpool condensed dryer
