PANDIGITAL Novel 7 Logo
Shirley Pleasant Posted on Mar 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keyboard out of synch on pandigital novel
When typing a letter on the keyboard the letter that appears is either below or next to the letter selected
Owen Barnes
Level 3:
Top Expert:
  • Master 867 Answers
  • Posted on Mar 06, 2012
Owen Barnes
Master
Level 3:
Top Expert:
Answers
867
Questions
0
Helped
399161
Points
2534
You need to go into the setup and run the calibration app to get the keyboard to line up with the touch panel.
5 Related Answers
Logicl77
  • 17 Answers
  • Posted on May 14, 2011
SOURCE: is there a compatible flash player type for
If you are referring to flash memory, yes it can be expanded with flash sd memory type sd/sdhc, mmc/mmc+ up to 32gb. You can find more information on the specs here:
http://www.pandigital.net/search.asp?Mode=Product&TypeID=43&ProductID=393
Lewis
Anonymous
  • Posted on Jul 10, 2011
SOURCE: I cant get the pandigital novel to turn on and it
i have the same problem
Anonymous
  • 8 Answers
  • Posted on Aug 22, 2011
SOURCE: when i try to type words it types in different
diz iz bcozz of "virus" nd u should make a quik scan to avoid further problems. . . . . . . !!!
Anonymous
  • Posted on Nov 30, 2011
SOURCE: Used wrong charger on pandigital novel
I put my pandigital on the charger and it sparked and now it's not working
Anonymous
  • Posted on Dec 15, 2011
SOURCE: Having difficulty finding a video converter compatible to pandigital novel 7
hi, toyo, may be this tools i use for my ipad can help you, video converter
How do i reset to factory mode if i forgot my pattern
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the Pandigital Novel 7 to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your Pandigital Novel 7 and including third-party applications.
9. The Pandigital Novel 7 will reboot to its original data.
10. This time you can restore your backed up data to your phone.
Forgot password
Go to Barnes & Noble's website on your computer and select the option to create an account. Enter your full name, email address, debit or credit card information and select a user name and password when prompted.
If you have a Barnes & Noble account, skip this step.
Power on the Pandigital Novel and tap "Settings" on the home screen.
Tap "General, and select the "B&N Account" and "Password" fields and enter your Barnes & Noble account login information.
Reading ebooks is not the only activity you can enjoy with the Pandigital Novel.
The multi-functional device will also allow you to listen to music, watch videos and browse through your favorite images.
The Pandigital has a speaker located in the back of the device and an earphone jack to accommodate your listening needs.
To get started, you will need to either download media from a computer or purchase ebooks from Barnes & Noble online.
Downloading Media
Connect the Pandigital Novel's USB cable into the compatible mini USB port on the right side of the device. Plug the other end of the USB cable into the computer's USB port.
Click on the computer's desktop "Start" menu.
Choose the "My Computer" or "Computer" folder in the desktop Start menu.
Double-click to open the "PD_Novel" drive in the My Computer/Computer folder.
Inside the drive there are four separate folders "eBooks," "Photos," "Music" and "Videos."
Drag compatible media files stored on the computer to the compatible folder inside the "PD_Novel" drive with your mouse.
For example, drag audio files to the "Music" folder.
The Pandigital is compatible with text formatted as ePub and PDF, audio files formatted as MP3, AAC, WAV and OGG, video files formatted as MPEG-4 and images formatted as JPEG, BMP, PNG and GIF.
Disconnect the Pandigital Novel from the USB cable.
Playing Media
Press and hold the "Power" button, located on the left side of the device until the boot up message appears on the screen.
Select a media option in the "Application Quick Launch Bar" at the bottom of the screen: Reader, Music, Videos or Photos.
Tap the desired song, video or image and tap "Play" or "View."
Tap the "Pause/Play" and "Previous/Next" options to control the file or go to the next listed file.
Setting Up Wi-Fi
Turn the "Wi-Fi" button, located on the top of the device, to the "On" position.
The Pandigital Novel will automatically scan for local Wi-Fi Networks.
Tap the desired network from the list of found networks.
Enter the network password, if prompted. Then tap "Connect." When connected, tap "Next" to continue.
Purchashing eBooks
Tap to go back to the home screen.
Select "Bookstore" from the home screen.
The Barnes & Noble bookstore will open in the Pandigital Novel screen.
Search the website for ebooks to purchase.
Tap on the book cover and select either "Buy Now" or "Get Free Sample."
Tap "Yes" to download the media cover to "My Library" when prompted.
Go back to "My Library" on the home screen and tap on the media cover.
Confirm to download the ebook to your Pandigital when prompted.
The entire media file will download.
http://www.pandigital.net/userfiles/file/Downloads/UG_PRD07T-1_v3.4_09-10-10.pdf
Barnes & Nobel
http://www.bn.com/
When i push a letter it goes to the next lerrer
Calibration problems I assume. Try to recalibrate the touchscreen.
3helpful
How do i reset the pandigital novel white 7
Hello.
To reset your tablet: (found online):
  • Press the "Power" button on the Pandigital Novel to turn it on.
  • Tap the "Settings" icon at the bottom of the Home screen display, then scroll down the Settings screen to the "Privacy Settings" option.
  • Tap the "Privacy Settings" option, then tap the "Factory Data Reset" option on the next screen. You will see the "Confirm" prompt appear. Tap "Yes" to begin the reset process on the device.
  • Hope this helps.
    When i try to type words it types in different letters either next to it or below it but not what i type
    1helpful
    I have pan digital Android white frame Android I would like to use photo as wallpaper but I don ' t see that option
    Welcome to Fixya. If the unit that you are using is the Pandigital Novel 7. You can refer to the manual below on how to set the wallpaper. Please refer to page 47 for the steps and you can also use the manual to know more about the product.
    Pandigital Novel Manual
    If you have questions please let me know. Thanks for using Fixya.
    9helpful
    Is there a compatible flash player type for pandigital novel? is the memory of this device expandable?
    Lewis
    2helpful
    3answers
    My Pandigital EReader is frozen, it won't even go into sleep mode.
    My pandigital has been frozen on the pandigital novel options for 1 full day. How can i shut it down and read the books I have?
    Top PANDIGITAL Computers & Internet Experts
    vince
    ADMIN Andrew
    ADMIN Andrew
    Are you a PANDIGITAL Computer and Internet Expert? Answer questions, earn points and help others
