20 Most Recent
PANDIGITAL Novel 7 Questions & Answers
Hotmail account can't connect to the server. tried all advise with pop3
The outgoing server probably requires authentication (usually the same password as for the incoming server). Is your email client sending authentication? Look for a checkbox saying something like: "Outgoing server requires authentication."
Also, I just want to make sure that you can't use "smtp.live.com-25-TLS as the address for your server. The server is smtp.live.com, the port is 25 and encryption is TLS.
Can the battery in the pandigital novel be replaced
yes it can be removed just remove the back cover(the one under the pandigital logo)you will see the battery unplug the wire from the white connector. the battery is held down with tape so you may have to pry it out.
What are certificates?
it can be an official document like a birth certificate, or it can be like a gift card. it depends on the context you use it in.
Hello. My wife dropped her Pandigital and cracked
Yes you can bring it to a reliable and skilled cellphone technician specially if your phone is still covered by the service and parts warranty period just bring it to the accredited service center of PANDIGITAL together with your receipt when you purchase it..But if its not covered by the warranty period consider the cost of repair if the cost is almost the same when you buy a new one so it much better to buy a new one but if the cost of repair is not that high it is much better for you to hire the service for the repair of your phone..Hope it will help you..
How do i reset to factory mode if i forgot my pattern
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the Pandigital Novel 7 to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your Pandigital Novel 7 and including third-party applications.
9. The Pandigital Novel 7 will reboot to its original data.
10. This time you can restore your backed up data to your phone.
Why my pandigital novel doesn't get on when I push the button power.
I am working on one of these ask we speak, same problem - when I opened the case I saw that the solder connecting the power button to the board has broken. After a little research I learned that this particular tablet/reader is poorly made & this type of problem is common. It is possible you have the same problem...
When you first plug it in to charge it, do you see any activity? (charging indicator on-screen, firmware info, etc)?
Reset the username and password
The below link should allow you to download the appropriate manual for your item to show you how to do a hard reset ))
http://www.central-manuals.com/instructions_manual_user_guide_tablet_ebook/pandigital.php
