I know this might sound unrelated but i noticed the same problem solved by chance when i changed the actual engine oil. i drained engine oil thoroughly (overnight) and changed filter. after running it a couple of times the orange arrow stays off, this problem reoccurs once the engine oil ages so i change my oil and filter every 5000kms. my guess is that some sort of censor reacts to the old oil as i'm not sure how the two are related.
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever
issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND
FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on
car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Transmission shifting
problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid
leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into
reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This
will help.
Thanks.
AUTOMATIC TRANSMISSION FLUID AND FILTER?
-----------Transmission fault light on
car dash?
--------Transmission shifting
problem?
--------Transmission Slips out of 2nd gear?
leaking?
transmission fluid leaking?
reverse?
----------Transmission is making buzzing noise?
-----------This will help.Thanks.
volvo 1999 s70 awd
I changed the battery now the yransmisson does not shift it starts in 3rd gear and the arrow for the winter mode is flashing
