In the last couple days these 3 lights keep coming on while driving. When I turn off the truck and let it sit for a minute the lights will go off. But they keep coming back on for no apparent reason. Can you tell me what might be going on with the truck.
I had the same problem on my 04 titan. after several attempts, bleeding brakes, replacing brakes,they found both pressure sensors were shorting out. Hope that helps.
I had the same problem on my 04 Titan. I needed pads and rotors, replaced them and the problem stopped.
See if the following information helpful:
1. Keep an eye on the dashboard for the indicators marked "SLIP" and "VDC Off" which will tell you the status of the computerized handling system if handling isn't normal. "SLIP" will blink when VDC is operating. "VDC OFF" means the system is off. Turn the VDC system back on if the Nissan's handling is poor by pressing the "VDC Off" button until the light goes out.
2. Adjust your driving if "SLIP" comes on. "SLIP" means the road conditions may be slippery. The VDC aids in steering and stopping, but be careful, even if VDC is engaged.
3. Remove any aftermarket suspension parts like enhanced shock absorbers if the "VDC Off" light comes on and handling is bad. The VDC system is geared for stock equipment and tires only. Use winter tires or snow chains on snow-covered roads. VDC won't substitute for the correct winter equipment.
4. Don't drive on very inclined corners with high banks and leave the VDC switch on if the handling is poor with VDC on. The system can't operate properly in that environment. Disengage VDC, or avoid those kinds of roads.
I have the same problem, sometimes the lights are on and sometimes they are off. My pads and rotors are fine.
grinding in right rear pads are fine
