Ok so newer laptops usually have a "hot key" combination to enable/disable it try doing that to see if its off , if that is not the problem see if windows detects it it all if not you must go into the device manager and find the exact device name (or the manufacturers website) then you must find the driver and install it , if all else fails most new laptops have a small door that is placed over the wireless card make sure it is plugged in tightly if you do have to reinsert it it does not go straight in you must insert at a 45 degree angle then press in and down hope i could help!
Maybe you don't have your wireless turned on. Look on
both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle
the wireless on or off. Normally you would Press and Hold the FN function
key located at the lower left of the keyboard, then hit the correct F1 thru F12
key that toggles the wireless. The correct F1 thru F12 key to hit will
have the wireless signal icon )))) on it. Or it might have the icon of a tower
with the wireless signal icon )))). Normally the screen will display
Wireless On or Wireless Off when you toggle the wireless.
