Click the link http://www.videohelp.com/capturecards/dazzle-video-creator-platinum-dvc-170/730
This will give you details about various connection method.
It should be connected through a Firewire port.
Thanks
If the device is showing the error "device not found" that means either the software of the device is not loaded properly on the pc. or the usb wire is faulty. or its not getting connected firmly at the position in the usb jack of the printer or the device.. check out this. thanks.
(usb jack of the printer or the device.) sorry mistake not ---printer--- but computer.---
The installation instructions are as follows :
1. Put the installation CD into your CD-Rom drive.
2. Connect the Dazzle device to an open USB port.
3. An “Add New Hardware Wizard dialog box with USB Composite Device” will appear. Press Next.
4. Choose “Search for the best driver for your device” and press Next.
5. Uncheck all the boxes and press Next.
6. Windows should find the driver at “c:\windows\inf\ich2usb.inf”, press Next.
7. Now you will have to restart your computer.
8. An “Add New Hardware Wizard dialog box with USB Device” will appear. Press Next.
9. Choose Search for the best driver for your device and press Next.
10. Check Specify a location and press browse.
11. If you are using anything but WinXP, open the CD-Rom with the installation CD and choose the “Windows” folder. If you are using Windows XP then choose the WinXP folder. Press Next.
Now your Dazzle Digital Video Creator should be installed properly. Open the CPC CaptionMaker and select the button in the “Preview Window” panel. Click “Enable Video”. If video is being streamed into the Dazzle device you should now see video in the preview window.
for all the detailed instructions with proper diagrams and pictures click this link below and follow the step by step instructions
http://www.cpcweb.com/TechSupport/CapMak...
just click the above link directly
please rate the solution if helped by it.
feel free for further assistance.
thanks.
the picture of where to connect how to connect all is given in the link with a brief picture and instructions.
thanks.
