I have a Apple MacIntosh Performa 5260/120 that does not turn on. I have checked cables and electrical outlet and no problems. Nothing is happening, no screen, no bip, no noise, nothing. Can you help please ?
i just got mine from a friend but i'm not ready to open it up yet. one possible reason it is not working was that it is still too cold. it needs 50 degree f to operate. if that helps or if you can help me
You can't post conmments that contain an email address.
This unit never came with AA batteries, chances are removing the logic board and replacing the board caused the unit to work, but I believe it will only work for a short period of time.This unit never came with AA batteries, chances are removing the logic board and replacing the board caused the unit to work, but I believe it will only work for a short period of time.
The Apple Performa has a VGA video output, so any monitor with that has a VGA input/cable with it will work fine. You can find these monitors at places like Best Buy, Tiger Direct, New Egg, etc.
The only question left is how much are you looking to spend on a monitor.
What are the system requirements for using this printer?
A:
PC Compatible Requirements - An IBM
(r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium
(r) 133 MHz (for Windows 2000) processor (Pentium or higher processor
recommended) - Microsoft (r) Windows 98 or Windows 2000 - At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended) - 50MB of free hard disk space (100MB or more recommended) - VGA or better display adapter and monitor - CD-ROM or DVD drive for installing the printer software -
USB connection: a computer running Windows 98 or Windows 2000, with a
Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet
(2 meters) long. Using an improperly shielded USB cable-especially a
cable more than 6.5 feet (2 meters) long-may cause the printer to
malfunction. Apple Macintosh Requirements - An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port - For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended) -
For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is
running OS 8.1, you need to upgrade your operating system before
installing your printer software. To find out which operating system
your iMac is running, select About This Computer from the Apple menu. If
you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you
install iMac Update 1.1. Download the update for your system from Apple
at http://asu.info.apple.com. Contact Apple if you have problems
installing an update. - 16MB of available RAM (more recommended) - 50MB of free hard disk space (100MB recommended) - VGA display or better - CD-ROM or DVD drive for installing the printer software -
A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an
improperly shielded USB cable-especially a cable more than 6.5 feet (2
meters) long-may cause the printer to malfunction.
restart the computer. hold down the option key on the keyboard on reboot.
it will show a couple of icons select the Macintosh HD (ie the Mac operating system)
it should booting the Mac operating system.
once you are up and running within the Mac OS go to
Apple menu (apple icon, top left) > System Preferences > Startup Disk
Select the Macintosh Hard drive. this makes sure that after you reboot that it will boot into the Mac OS.
You might want to try the Apple Mac OS USB DDK - 1.5.5f1, which has 3rd party support for USB cards
http://developer.apple.com/hardwaredrivers/download/
choose the Mac OS USB DDK 1.5.5 for Mac OS 9 (IMG)
Copy the extension into your System Folder:Extensions Folder and restart
As I recall, this is a SCSI device. Like many electrical connectors, SCSI connectors can develop a light corrosion which can keep the signals from being transmitted. The easiest way to clean such light corrosion is to shut down the Mac & power down *all* SCSI devices in the chain. Then gently unplug & replug all SCSI connectors. This will scrape off much of the corrosion & usually results in connectivity being restored. Be sure to unplug and replug the SCSI terminator attached to the last device in the SCSI chain. Restart by powering up the SCSI devices and finally restarting the Mac. Good luck!
I cant find the machine DCP-7020 but I think this machine is the same with model MFC-7420 if you have the installer CD follow these steps:
For USB Interface Cable Users For Mac OS® 9.1 to 9.2 & Software 1 Turn off and
unplug the MFC from the AC outlet and disconnect it from your Macintosh, if you
already connected an interface cable. 2 Turn on your
Macintosh. 3 Insert the
supplied CD-ROM for Macintosh into your CD-ROM drive. 4 Double-click the Start Here OS 9.1-9.2 icon to install the printer and scanner
drivers. If the language screen appears,
select your language. 5 Click MFL-Pro Suite to install. 6 Follow the
on-screen instructions, and restart your Macintosh. 7 Connect the USB
interface cable to your Macintosh, and then connect it to the MFC. DO NOT connect the MFC to a USB port on a keyboard or a nonpowered USB hub. 8 Plug in the power
cord and turn on the MFC. 9 From the Apple menu,
open the Chooser. 10 Click the Brother Laser icon. On the right side of the Chooser, select the MFC to which you want to print. Close the Chooser. The MFL-Pro Suite, Printer driver and Scanner driver have been
installed. To install Presto! PageManager, click the 11 Presto! PageManager icon and follow the on-screen
instructions. Presto! PageManager has
been installed and the installation is now complete. You can easily scan, share and organize photos
and documents using Presto!PageManager.
OSX
1.
Click on the Apple menu and select the System Preferences option.
2.
In the "System Preferences" window, Select Network.
3.
When the "Network" Window opens, select Built-in Ethernet and/or Airport from the "Show" Menu.
4.
Once you do this, look near the bottom and you will see the Ethernet Address or Aiport ID. This is the MAC Address, make note of it.
OS9 and below
1.
Click on the Apple menu option.
2.
Go to the Utilities folder
3.
Open the program called Apple System Profiler
4.
Select the System Profile tab
5.
Under Network Overview > Appletalk>
6.
Once there you will find the Hardware address, this is the MAC Address, make note of it.
Dear Mr. Expert,
It was found that 3 AA batteries needed to be replaced in order to turn the mac back on.
