Serial # mbo207315
SOURCE: dryer stopped spinning,timer still ticking,cannot get to restart.
Can you still hear the motor turning? If the motor is running but the drum is not then it is probably a broken belt or there may be something blocking the drum from spinning. The first thing to check is if the drum will turn by hand. If so, the next thing to check is if the belt has broken or slipped off. Although it is a bit cumbersome to replace, it is easy to diagnose. Unscrew the screws holding the back of the dryer on and pull the cover off. Look at the pulleys on the motor and see if the belt is intact. If those solutions don't do the trick, let me know and I will try to give you other options.
SOURCE: Whirlpool dryer model # LEC6646A will not power
The fuse is probably
gone due to some
sort of air blockage.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: timer ticks, but dryer does not run
Sounds like door switch. Open door and push on door switch. you should here a clicking noise. If you can open the top of the dryer. put the 2 wires together of the door switch. Make sure it is unplugged when doing this. Make sure you use electrical tape when you put it together. Temp fix. Get a new switch
SOURCE: the dryer won't start. the timer is ticking, but ...
check the door swich see if it is catching,,,,the switch is on the inner part of the door frame,,,,if that dose not work look into the thermofuse ....if dryer making a nose atattempted start up you may need a motor,,,,,,,,,www.myabcspace.com/washerwizzards
