SOURCE: VFD-B inverter control with external volume like switch
You better buy a multi turn potentiometer about 4,7 - 5,1 kOhm.
Connect its ends to "+10 V" and "ACM". The Slider connect to "AVI".
The multi turn pot can make small steps of adjustment.
Hope that it will help.
SOURCE: DELTA INVERTER VFD-B PROGRAM HAS BEEN LOCK
First thee attempts will "lock" you out. you must restart drive to allow 3 more tries. If you can't get to programming funcitons to change password you should be able to connect via serial connection and reset the password funcitons to 0. See attached pdf file for directions to connect pc to drive: http://www.delta.com.tw/product/em/control/cm/download/manual/IFD9507_application_en.pdf
If you don't have your manual to expalin password functions you can also find it at:http://www.delta.com.tw/product/em/download/download_main.asp?act=2&pid=1&cid=1
SOURCE: Delta Vfd220b43a Ac Drive Vfd B Inverter 30hp 22Kw
good day. I have a pump that i want to start / stop with a pressure switch. How will i connect this ?
Thank you
SOURCE: I want to know the
You can find the price from eBay, Amazon or Google Shopping.
Testimonial: "Thank you! I find the price!"
