Found that the fuse was blown for the tail lights changed it. Press the brake pedal a couple times and the fuse blew again. Abs and brake light in dash is on. I know I have a bad wheel speed sensor on passenger front. So I know why the abs light is on. So need to know why this fuse keeps blowing
SOURCE: abs kicks in at low speed and pedal pressure
You have a weak or bad ABS sensor on one of the hubs. They are built into the hub and are not individually replaceable. Also rust buildup around the sensor will cause this same problem. To stop the ABS from kicking in untill repair just pull the fuse.
SOURCE: bleeding abs brakes
Try using a pressure bleeder. It will force the air out. Works every time.
SOURCE: 2001 Mercury Grand Marquis brake and ABS dash lights on and off
The red brake light is the key here. That usually indicateds a hydraulic problem. Check you fluid level in master cylinder and see if it is low. Also the level indicator sensor there in the master cylinder maybe sticking or corrioded. If ABS sees the red brake light it will shut off and turn on the ABS light,also traction control would be disabled as well.
SOURCE: No tail lights on 1991 Chevy Silverado. fuse is good
sounds like a broken wire in the harness. look around the bumper area,sometimes along the frame. may have to peel back some tape covering. also if you have a trailer harness look closely at those.
