Pro tec car seat, to remove covers for washing.
SOURCE: removing maxi-cosi priori cover
There are 3 different Priori models - here is the link to the instructions and video for the Priori SPS; http://www.maxi-cosi.com/maxicosi/productdetail.aspx?id=20 if you have the Priori Fix or XP then go to this link and select them under "Car Seats". Also shows link for contact details for Maxi Cosi; http://www.maxi-cosi.com/maxicosi/default.aspx?language=gb-en Hope this helps :)
SOURCE: removing seat cover
Dorel Juvenile Group manufactures these car seats for under the Cosco brand. You should check out their web site.
There does not seem to be any Manuals on their website, but they do list a phone number. 1-800-544-1108
When I took mine apart I did the following.
I think that is all I did. We washed the cover in COLD water on delicate and soaked it overnight to get it clean. Hang dry!
SOURCE: REMOVING COVER COSCO ALPHA OMEGA ELITE
Unscrew the bolt of buckle and housing of the belt are below nbot attached to the carset.
SOURCE: how do i remove maxi cosi car seat cover for washing please
hi bodsierpa..hope this helps..good luck!!!
• First remove the belt pads.
• Open the rim at the sun canopy as far as possible
• Remove the cover from the hooks
• Remove the cover then from under the hooks and quick adjuster button
• Pull the buckle tongue sections and adjustment strap through the openings.
SOURCE: removing seat cover maxi cosi priorifix
Peel the cover from around the seat frame so that the shoulder strap hold the cover on to the seat. Extend the set belts to their maximum length and recline the seat as far as possible. Looking at the seat from the front, put your hand in the gap between the reat of the seat (bit that reclines) and the fromt of the fixed base (by the red dome and the instructions). On the bit of the seat that reclines there is a 'door' that opens to reveal a metal clasp that the ends of the shoulder straps fix to at the top and the **** belt at the bottom. Unhook the looks from the shoulder straps from the metal clasp. Pull the shoulder straps through the back of the seat upright. You can now pull them through the cover which is free for you to was. A great design hey ! Good Luck.
