Sim ic jamper
SOURCE: Display problem - sony ericsson Z530i
firsty change ur body
after that change it patta
allright
SOURCE: insert correct sim card
i you should try a software update, you can get this from www.sonyericsson.com/support. hope this helps
SOURCE: insert simm error n my sony ericsson w200i
there could be a issue with the contacts on the phone. the 6 pins where the SIM gets fixed. clean with the tissue & try again. if it's the same .. suggest you take it to a repair shop.
SOURCE: Sony Ericsson W880i sim problem, displays insert
Hi! Most probable the sim reader from your phone is detached from the phone`s motherboard. You need to go to a service and check this. Good luck!
Testimonial: "Thanks will do"
