well i bought these speakers and only an alert sound witch says system failed cpu test i dont even know what that means can someone help me plz well i bought these speakers and only an alert sound witch says system failed cpu test i dont even know what that means can someone help me plz
You can't post conmments that contain an email address.
Plug a pair of earphones into the iPad to see if the problem is the speakers or the iPad. Once you have the piece that's not working correctly figured out, it's time to take it to the repair shop.
The adapter is probably a mono adapter. The jack plug should have three parts (two rings and a tip). Stereo requires 3 connections, one ground, one for left spkr, one for right spkr.
try swapping the speakers around if the problem still persists either the speaker is faulty or the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems hope this helps
If it works on another computer without any problem, then problem might not be with your speaker, it must be with the computer's probably with sound settings. I think it was working with your windows XP running desktop and your other laptop, but it doesn't work with another (new) computer. If so, could you please let me know the model and make of your new computer with the operating system installed on it? If the sound card on your new computer is onboard, then I will be able to find out the details about the sound card and it's related software and I would check out it's settings/features. But if in case the sound card's purchased separately and you installed it, then I would need that sound card details.
If my assumption is wrong and your problem is with your speaker, then I won't recommend you to get it repaired. If it's a new item and you still have the warranty unexpired, then that's another case, and so this would be your time to use the Warranty.
It's probably the speaker, not the wiring. I've got one speaker that goes in and out, mostly out. Turns out the diaphragm is getting stuck to the magnet. After seeing the wiring checking your speaker connection would be a much easier place to start.
We hooked up an external speaker to the contact points and got sound, plugged the original back in, no sound. A simple un-intentional patting to the speaker and it started working again.
Will probably be replacing soon.
As a side note, crutchfield sent me some nice installation instructions when I purchased a new wire harness to put in a new radio. Pretty detailed and with photos. Getting in there takes a bit of work, but trying to trace wires would be painful.
if you happen to have a speaker available, try to test the stereo. plug in a speaker and see if it works. otherwise, i don't really like this method but, it does work... unlug your factory speaker and plug a 9v battery to the speaker, if you hear a little popping/wizzing sound, the speaker works and it's the head unit.
also, check to see if the radio has an amp. sometimes the radio will be operational, but the amp isn't and that is the problem. and the easy solution is to replace the radio with an after market of choice. factory radio's that are purchased seperately are rather expensive.
It's less common for one of the speakers to go bad in a set of headphones. It's possible - but there are more common problems that will cause this. I assume you have tried the headphones on another device to rule our a problem with the device you are currently listening with and using the other device, you still only hear audio from the left speaker.
The wires in the cord that connect the plug to the headphones are very thin and are susceptible to breaking. The most commmon place for these wires to break is at the point where the cord is flexed or stressed the most. Those points are:
1. Right at the plug
2. Where the wire enters into the left and right speaker.
There are occasions where I have seen the wires become unsoldered from the speaker terminals within the headphones themself.
What You Can Do:
1. While listening with the headphones, try flexing the cord back & forth at the plug and where the wire goes into the right speaker. See if the audio will come back and cut out again.
2. What I have done is cut the cord about 3" back from the plug. Go to Radio Shack and purchase a new plug and install a new plug on the cord.
3. You can also take the headphones apart and cut a few inches off the cord where it connects to the right speaker and reconnect the new end of the wire to the right speaker. The goal is to cut away the bad part of the cord and re-attach the good part back.
4. You can try to replace the entire cord but I haven't been able to find replacement (THIN) cords too easily.
