I bought 2000 lexus RX300 couple days ago. After i drove 130 miles. it does not want move from starting point. I gave more gas finanlly it did move hard to shift next gear .now it won't go forward at all.when i put it in drive only racing like in nutural. it does go backward fine. Is it transmission totaly broke? Any thing I can do other than rebuilting or replacing transmission?
SOURCE: replace side marker light on lexus rx300
Remove 3 - 4 screws on fender cover close to side marker light. Pull fender cover out a bit for you to use your other hand to reach side marker light. By twisting on one direction and here you go the light out. Replace new bulb and replace everything on reverse order.
SOURCE: Replacing outer tail light on Lexus RX300 ?
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Lift the hatch. The tall center light is located behind the
upper hatch inside panel. There are two
panels need to remove. One panel is on the right, the other on the left. To
remove the panels you have to use flat screw driver to pry out the panel in
several locations. (These panels are secured by several small metal clips.) Be
careful to collect all these clips and replace them on the back of the panel.
You will need these clips to replace the panel later on. After remove the panels,
you will be able to locate the screws on the tall center stop light assembly. Remove
those screws and cover. After replacing light bulb. Assemble everything in
reverse order. Remember, the metal clips have to set on the back of the two
panels not the car body.
SOURCE: ? to Replace Timing belt on 2000 Lexus Rx300 with 57,000 miles.
If it is running perfectly I wouldn't think that you would need to replace the timing belt. You shouldn't need to replace that until 100,000-120,000 miles. I would definitely hold off until now unless you have start having some timing problems. Let me know if you have any other questions. Thanks for rating my response and for using FixYa!
SOURCE: Lexus RX300 engine light n VSC light comes on
VSC means Vehicle Stability Control.
It comes on when the sensor send a signal that the vehicle is not stable on the ground.....check the wheel balancing and alignment and the air pressure of your tires too.
Good luck.
Rate this solution.
SOURCE: changing rear wiper fluid in a 99 lexus rx300
Nothing to change, add fluid to the reservoir in front. Lack of rear fluid could indicate a bad pump or hose connection feeding to the rear area or clogged sprayer tip
