How to replace rear paper tray clip
First, remove the paper tray from your printer. On a Canon printer, this is done by pressing the release clips located on the right and left side of the paper tray. On an HP printer, press the release button to remove the paper tray. Once the paper tray is released, locate the broken paper tray clip. This clip is usually a plastic piece that is clipped onto the paper tray. Using a pair of needle nose pliers, carefully remove the broken clip from the paper tray. Once the broken clip is removed, carefully inspect the paper tray to make sure that the area where the clip was attached is clean and free of any debris. Next, locate a replacement paper tray clip. You can find these clips online, or at a local office supplies store. Using the same needle nose pliers, carefully attach the new clip to the paper tray. Make sure that it is securely attached to the paper tray. Finally, re-insert the paper tray into the printer following the same instructions used to remove it. Once the tray is inserted, test its functionality to ensure that the new clip is securely in place.
