1998 Volvo V70 Logo
Anonymous Posted on May 13, 2017
Door handle stuck
I was trying to reprogram a keyless entry remote by turning the key 5 times in less than 10 seconds and on the 5th try use my remote.  Well that didn't work for one, and then my inside door handle on the front passenger side is stuck and won't open.  It will open from the outside just fine. There are no child locks in the front that i can tell. Please help me if you know how to get this handle functioning again. And it would be a bonus if you know how to program my keyless entry remote.
thanks, casey
Robert Larose
Level 2:
Sergeant:
  • Expert 198 Answers
  • Posted on May 13, 2017
 Robert Larose
Expert
Level 2:
Sergeant:
Answers
198
Questions
0
Helped
49776
Points
627
Okay u need to turn key on the number 1 position 5times on the 5th time leave key on number 1 position the within 30 seconds need to push the lock or unlock button ONCE but you need to do all remotes even the ones that work to reprogram all of the to now work the car.
also if door handle does not fix itself after this reprogramming you will need to remove the door panel and free up lock rod
john h
Level 3:
Top Expert:
  • Volvo Master 29,494 Answers
john h
Volvo Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7561217
Points
193449
Need to remove door panel either the linkage clip either broke or disconnected --if have remote start on fob need dealer to program--if normal try these links
Lexus Free Keyless Remote Fob Entry programming instructions Free Keyless Remote Fob Entry programming instructions procedures for all...
5 Related Answers
Anonymous
  • 41 Answers
  • Posted on Nov 08, 2008
SOURCE: Reprograming a keyless remote
program transmitter code(s) as follows:
1) Confirm that all the doors are closed and the ignition key is out of the ignition cylinder.
2) Open the driver’s door. Insert the key and turn the ignition switch to ON position within 10 seconds.
3) Turn the ignition switch to OFF position within 10 seconds, remove ignition key from lock cylin-der.
4) Push and release the driver’s door switch (1) 3 times within 20 seconds.
5) Insert the ignition key and turn the ignition switch to ON position within 10 seconds.
6) Turn the ignition switch to OFF position within 10 seconds, remove ignition key from lock cylin-der.
7) Press and hold both LOCK and UNLOCK buttons (2) on the transmitter (3) for more than 5 seconds
within 20 seconds of removing the ignition key from the lock cylinder in step 6.
8) Press LOCK or UNLOCK button (2) on the transmitter (3) within 5 seconds (after step 7). All the
doors will lock/ unlock to confirm that this process has been properly done.
With this process, the transmitter has been programmed.
9) If you want to program an additional transmitter, repeat the procedure from Step 1) through Step 8).
10) Make sure that the keyless entry system properly operates by operating each transmitter.
zappanut
ZappaNut
  • 960 Answers
  • Posted on Dec 15, 2008
SOURCE: reprogram keyless entry system
1991-94 Nissan Maxima key less entry reprogramming procedure:
1. Enter the *original code found under the dashboard.
(*the code begins with the letter F and has 7 digits)
2. Close the doors and lock all of the doors,
enter the 7 digit code ( make sure you have your key in hand).
3. Once the code is entered correctly you will hear a long beep ♪ ♫.
While the beep ♪ ♫ is sounding ... ENTER your NEW 4 digit code, (you will then hear random beeps ♪ ♫)
Do not touch anything until the beeping ♪ ♫ stops.
4. To open the doors, the front windows and the trunk,
type: S(Clear) and the New 4 digit code and the door will open automatically.
5. IF by any chance you forget your new code. Just enter the original one and start all over.
240cpa
  • 548 Answers
  • Posted on Jan 25, 2009
SOURCE: Door will not open on 1998 V70 wagon
You have a broken latch that you will need to access from inside the car. Remove the door panel carefully and have a magnetic pickup tool handy to fish in the bottom of the door for any parts that fell to the bottom when the latch let go. To cheat, remove the door panel from the rear door too and you can see what is missing from the broken one.
Anonymous
  • Posted on Jan 27, 2009
SOURCE: Alarm haywire, can't override anti-theft system or turn on car
The Alarm on my Mercedes ML320 sounded every night, then it started doing it more often, Showed it to the dealer he says it's the 'Tow Sensor', that needs to be repaced. $700, down the drain. I have already started hating this car, it eats $500-600, every 6 months...
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Nov 20, 2009
SOURCE: using the remote or the door lock inside the car not working
remove the door panels and give everything in sight a good squirt of engine oil in a proper oil can .DO NOT USE THAT SPRAY FISH OIL STUFF ,wd40
2answers
How Do I Know If My Car Equipped With A Keyless Entry Remote System? I have a 1999 Ford Windstar. I bought several remotes but can't get my locks to engage. Any help would be appreciated.
Hello Cathy
It does indeed have keyless entry. It needs reprogramming when you get a new remote. Also if you disconnect the battery. Usually a local car alarm fitting shop, or an auto-electrician will do it. Plus of course a Ford dealership.
https://www.google.com/search?q=Keyless+Entry+Remote+System+1999+Ford+Windstar
I went through programing as far as lock recycling but wont go any further
Remote Transmitter Programming NOTE: All keyless entry remote transmitters must be programmed at the same time.
NOTE: Programming (or reprogramming) the keyless entry remote transmitters into the central security module can be accomplished using a diagnostic tool or by carrying out the following steps.
  1. Turn the ignition switch from OFF to RUN eight times within 10 seconds, ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after Step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the doors will lock and unlock one last time to confirm.
2004 Suzuki Gran Vitara Keyless entry
Try this
2004 XL7
1. Remove key from ignition switch.
2. Close all doors.
3. Open drivers door
4. Insert key and turn to ON position and within 10 seconds turn
key off and remove key.
5. Within 20 seconds Close and open drivers door 3 times.
6. Insert key and turn to ON position and within 10 seconds turn
7. Locks should now lock and unlock automatically to confirm you
have entered programming mode.
8. Press the UNLOCK button on remote and locks should cycle to
confirm programming.
9. Repeat step 8 on each additional remote.
10. Exit vehicle with keys and remote, close door test remote(s)
2001 mustang keyless entry not working properly what do I do
You did it like this ?
Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
  1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
  1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met. Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
  1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
Reset code for 2005 Ford Focus keyless entry remote
So this answer is on the same topic of a 2005 Ford Focus keyless entry remote. There is no way to "reset" the code from the vehicle, however you can reprogram an existing or program a new keyless entry remote to your Ford Focus by using these simple instructions:
*** THERE ARE 2 POSSIBLE PROGRAMMING PROCEDURES. ***Procedure #1
Note: Obtain all remote transmitters for this vehicle.
Note: Do not depress the brake pedal during procedure.
  1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door locks will cycle to confirm programming mode. (Off is the position where you can remove your key, RUN is the position just shy of starting your car.)
  2. Within 20 seconds press any button on the first keyless remote to be programmed. Door locks will cycle to confirm programming. If you only have one remote then skip to step 4.
  3. Within 20 seconds, press any button on the second keyless remote. Door locks will cycle again to confirm programming. Repeat step 3. For all other remotes.
  4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
    Procedure #2
  5. Note: Obtain all remote transmitters for this vehicle.1Fasten seat belts and close all doors.
  6. Turn ignition from OFF to RUN 4 times within 6 seconds, with the 4th time ending in RUN. (Off is the position where you can remove your key, RUN is the position just shy of starting your car.)
  7. Turn ignition to OFF. Acoustic signal will sound and system warning lamp will illuminate to confirm programming mode.
  8. Within 10 seconds, press and hold any button on the first keyless remote. Wait for acoustic sound and warning lamp to flash (confirming programming) then release button on remote. Wait 2 seconds but within 10 seconds repeat step 4. For all other remotes. If you only have one remote then continue to step 5.
  9. Turn ignition to Crank or wait 10 seconds to end programming mode.
6helpful
Keyless remotes not working
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the RAP module, perform the following steps:
  1. Make sure that the anti-theft system is not armed or triggered.
  1. Turn the ignition switch (11572) from OFF to RUN eight times within ten seconds, ending in RUN. If the RAP module has successfully entered program mode, it will lock and then unlock all doors.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the RAP module will lock and unlock all doors one last time to confirm.
2answers
Can't program Second remote to my Ford Explorer 99
Programming a key fob is all about timing. You are most likely doing everything correctly, just not in the correct time sequence. Keep at it, it might take you a dozen times, but you can get it. A tip is to do it as quickly as possible.
Here are the programming instructions:
*** THERE ARE 2 POSSIBLE PROGRAMMING PROCEDURES. ***Procedure #1Note: Obtain all remote transmitters for this vehicle.
    Procedure #2Note: Obtain all remote transmitters for this vehicle.
  5. Fasten seat belts and close all doors.
Bonus Tip: You can save time and money purchasing a Ford Explorer Key Fob online from Keyless Entry Remote Inc.
96 sable wagon keyless entry
Try re-programing the system.
These are the instructions from the service manual.
. Turn ignition from OFF to RUN 5 times within 10 seconds, with the 5th time ending
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
3. Within 20 seconds, press any button on second keyless remote. Door locks will
2helpful
2answers
Reprogram a keyless entry remote
Hello
this is how to program the remotes/keyless entry
How
  • Obtain all remote transmitters
  • enter the 5 digit permanent code into the keyless entry pad on the drivers door
  • Press the 1-2 switch on the keyless entry pad
  • Within 5 seconds
  • Press any button on the first remote transmitter
  • The doors should open then lock
  • Within 5 seconds
  • press any button on the second & third remote
  • within 5 seconds for each remote
  • to exit programming
  • simultanionusly press 7-8 & 9-0 switchs on the key pad or wait more then 7.5 seconds
NOTE
The 5 digit permanent code is located in one of the following places
  1. On the owners warranty card
  2. On the label on the inside the trunk/ boot
  3. On the owners code card
  4. On the centrel locking control module located in the drivers door
  5. In the PCM ford can get this for about $25.00
I hope this help
Regards Paul
www.limotec.co.uk
1helpful
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
