1995 Chevrolet Lumina Logo
Posted on Jan 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I had absolutely no power and I couldn't even jump
Timmy L Costa
Level 2:
  • Expert 142 Answers
  • Posted on Jan 26, 2012
Timmy L Costa
Expert
Level 2:
Answers
142
Questions
Helped
155296
Points
516
No Power? Do you mean that the engine would not crank when you turned the key? Did you have dash lights? Dome lights? If you had some kind of lighting, you had electrical power. and if that is so then it sounds like your transmission range selector switch may be faulty or needs adjustment. Or VERY POSSIBLY, you might not have put it ALL the way in Park when you turned the car off the last time. If you try it now does it start? If not try putting it into park a little harder. Does that work? If not put in Neutral and try it. If that works the Gear selector switch Is bad or in need of adjustment.
Oldsmobile cutlass ciera
Could be crankshaft sensor.
1helpful
Two months ago I went through the car wash and my ebrake and battery lights started flashing intermittently heater blower losses strength when I accelerate and the headlights dim. Started idling crappy at...
it sounds like you have a bad ground. follow all your ground wires. should be one to the engine, body, and maybe frame. disconnect them and clean the surfaces with sand paper and reconnect
My VW golf TDi won't start since I changed my battery. It started fine for three days and now there is absolutely nothing there when I turn the key not even a click. Please help
1. Do all lights, accessories, central locking system etc in the car all operate normally.
2. Have you tested to see if the car starts when you try jump starting from another vehicle.
3. What warning lights were displaying on the vehicle a day or 2 before you had the problem.
4. Were you having the same starting problems with the old battery that you have just replaced.
2004 Ford Explore won't turn over
whilst you are trying to jump start it check if you jump leads are good and powerful enough to sent the power to your battery,check if your battery terminals are clean enough to accept the power given,or is your battery not completely dead and even you are boosting has not the power to increase the needing one to start and is just for lights only?
Our 2007 Jeep Grand Cherokee randomly won't start.
change the wires that go to the starter i had the same problem fixed now with no problems
HUNDAI 2000 elantra will not start. it has no power at all . acts like a fuse is blown
it could be a fuse,, check in the fuse box under the hood for one that says Start or ignition, if you have zero power to the car, No lights, radio, nothin, check the battery posts , clean them and tighten them up, if they were to bad then the alternator couldn't recharge you battery , try jump starting it but let the powered vehicle run for a while with the cables attached to your car to assist in charging your battery ,, then try and start the vehicle
I have a 2001 Chevy Blazer 4x4 and I want to convert it to a 4x2
The question is why?
Do you live where you don't ever use 4 wheel?
Why would you now a vehicle is 11 years old,
even worry about, what will be a hobby or some
sort of restoration project
You won't get any improvement in gas mileage
& you absolutely have to do all that work yourself
It simply isn't done professionally & you couldn't
afford it if it was.
Buy a different vehicle or trade with someone who wants
4 wheel & has what you want.
3answers
1990 v6 3.1 liter firebird wont start.
Did you try to start it in neutral? could be park neutral switch.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
