Gigabyte GA-5AX Motherboard Logo
Posted on Oct 09, 2008
Processor Compatability Can I use 1-2g processor with it?
  • Anonymous May 11, 2010
    What do you mean with 1-2g ?
Anonymous
Level 1:
  • Contributor 23 Answers
  • Posted on Oct 09, 2008
Anonymous
Contributor
Level 1:
Answers
23
Questions
0
Helped
8897
Points
59
Yes you can, it seems to support a wide variety of things, here is my source.
1. Socket 7 for Intel MMX, AMD K6 -2, K6 -3, IBM /Cyrix , IDT processors
2. Supports CPU multiplier 1.5/2.0....../6.0 for future processors
3. 66/75*/83*/95/100/105*/110*/115*/120*/125*/130*/135*/140* MHz FSB
4. CPU voltage 1.3V~3.5V
Hope this answers it!
1helpful
E21088 compatability
I see no reason why you couldn't. The motherboard supports the CPU's socket, and the GTX 660 isn't that powerful of a card. So long as you have a sufficient power supply (no less than 500 watts) you'll I see no reason why you couldn't.
3helpful
2answers
Will an amd 3800 dualcore processor work with an acer aspire m1610
No, only Intel Core 2 Duo processors fit into the motherboard in this PC.
Compatability
Check Intels website, when you find your processor check the x64 bit mode should say: Yes or NO. That will tell you. I don;t know your processor your using.
1helpful
2answers
Have installed a new Core 2 Duo 3.16Ghz,6MB replacing a core 2 duo 1.86Ghz processor and my computer will not boot. My motherboard is a Gigabyte GA-945GMF-DS2. Are you able to give me any...
Here is the Processor compatability list for that motherboard:
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2408
I did not see the 3.16 GHZ processor on the list.
You can download the manual from here:
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=2408
Their website is slow, but it get to the link.
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Uppgrade to a faster processor
to decide cpu compatability we would know the model of the motherboard.
Robert
Processors have a matched frequency rating with the motherboard and memory. So, when replacing or upgrading the processor, the new processor will need to have the same frequency as the old one. If the processors use the same type of memory, ie... PC2100, then ther are most likely compatable, and the use of a processor that was made for or from the same make of laptop is always a good idea. Some processors are designed specifically for use in certain manufacturer's system configurations. For example; say you have a Dell Latitude C840 with a 1.8ghz processor and you want to upgrade to a 2.2ghz processor from a Dell Inpiron 8600, this will work. Both of these machines use the PC2100 memory and have a matched frequency rating of 266mhz, and the processors are made for use in Dell machines. If you would like to tell me exactly what you're wanting to do, maybe I can recomend a processor for you. Let me know.
Compatability issue
As far as the system is working. there are no problems with comptability..
If possible try updating the bios to latest version 0047.
Motherboard compatability
The AMD quad core processor will work on motherboards which have the appropriate socket set/size for that particular processor also ensure that your ram is compatible with your processor frequency otherwise you could experience problems.
Directx10.1 compatability
DirextX compatibility is determined by the video card, not the processor.
You need to check your video card's specs for DirectX compatibility.
2answers
Processor compatibility- ASUS P5S800-VM
Asus P5S800-VM do NOT support Core 2 Duo: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S800-VM
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
