Santa just brought my kid one of these and we took it out this morning and when he pressed the accelerator the back wheels spinned in opposite directions. I know this model has a "differential" type of rear axle but with him sitting in it on flat ground i think it should work. Any ideas?
The polarity is reversed on one of the motors, if the gear selecter is in low or high gear the wheels should propell the vehicle forward, whichever wheel is not propelling the vehicle forward switch the wires around on the motor
SOURCE: wheel spinning / traction issue on toy gator
First off, keep in mind that there are reasons why they make the wheels of this slipper plastic - like reducing the risk of burning out the motor. That said, you know those rubber pedal extenders for infants (the things that come with 2 wooden blocks and a large rubber band, they 'may' be big enough to stretch around your wheels. Also have a look around for LEGO rubber tracks. There are some out there that may be large enough as well. Check here.
SOURCE: Rear wheels-
Both wheels should spin in 2nd gear. Only one wheel may spin in 1st, but if you put a little pressure on the one wheel that spins it should make the other wheel start spinning.
But both wheels should spin in high gear at the same time.
Hope this helps. If there is more help you can also ask these guys at this website. http://www.shopjandl.com/ I get my parts from them and they seem to also work on them as well
SOURCE: Power
The battery seems to be bad. I get my Peg Perego Batteries at http://www.shopjandl.com/
My batteries last about 3 to 5 years, as long as my kids are charging them up each time they go down.
Hope this helps
SOURCE: We have charged it and the wheels spin for a
I sounds like the fuse is kicking off.
I would contact the repair help at
They are a great help for my ride on toy problems.
hope this helps
SOURCE: gator lt wheel doesn't turn when in grass/ slips easily and need
You could try new wheels if those are worn. Otherwise, Google "Gator Traction Bands"- an aftermarket company that makes bands just for these wheels.
If you need the tires, we can help.
http://www.rungreen.com/john_deere_peg_perego.html
