Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the computer is
off or in hibernation, turn the computer on, and then shut it down
through the
operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
Close the computer.
3. Turn the computer upside down with the front panel
toward you.
4. Remove the three Phillips PM2.5×5.0 screws that secure
the switch cover to the computer.
5. Turn the computer display-side up with the front toward you.
6. Open the computer as far as possible.
7. Lift the rear edge of the switch cover and swing it forward
until it rests on the keyboard.
8. Release the zero insertion force (ZIF) connector 1 to which
the LED board cable is connected and disconnect the cable 2
from the LED board.
9. Remove the switch cover.
Remove the Keyboard:
Remove the four Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
Turn the computer display-side up with the front panel
toward you.
5. Open the computer as far as possible.
6. Lift the rear edge of the keyboard 1 until it rests at an angle.
7. Slide the keyboard 2 back to disengage the tabs on the front
edge of the keyboard from the top cover.
8. Swing the keyboard 3 forward until it rests on the palm rest.
Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board.
10. Remove the keyboard.
Remove the Speaker Assembly:
Disconnect the speaker assembly cable 1 from the power button board.
5. Remove the two Phillips PM2.5×4.0 screws 2 that secure the speaker assembly to the computer.
6. Remove the speaker assembly 3.
Reverse directions to replace everything.
