How can I remove the aerator for cleaning?
Doesnt the bottom of the tap end unscrew as the the jet thing is behind this
I was able to remove the aerator from the spray head of the Everest model (302864 or 302861) by making a tool with two 7/64" drill bits and a short piece of oak. I drilled holes 1.5" apart in the wood with one of the bits, then pressed the bits into the holes leaving about 1/2" of the shanks exposed. This tool made unscrewing the nozzle from the spray head super easy. Removing the spray head from the flex hose was difficult, but easier after removing the aerator. This leaves a flat surface that I gripped with a wooden cabinet-maker's clamp with some padding (1/4" yoga mat). With a firm grip on the spray head, I was able to unscrew the flex hose retaining ferrule with an adjustable wrench. It took a lot of effort, being calcified.
SOURCE: Is there a way to remove the aerator from a
they unscrew from the faucet. counter clockwise.
if they are a little stubborn, you can use channel lock pliers, GENTLY grab the aerator with the pliers and GENTLY twist, counter clockwise.
do not use the pliers to re-install, just hand tight.
