These directions are taken from Apple.com.
Putting iPod into Disk Mode
http://docs.info.apple.com/article.html?artnum=93651
"1. Before manually placing the iPod into Disk Mode you should verify
that it has a charge, if not you need to either charge iPod before
continuing or connect it to power. You can either connect it to a
high-powered USB port, or plug the iPod Power Adapter into an
electrical outlet and connect iPod to the power adapter.
2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
3. Press and hold the Menu and Select buttons for at least 6 seconds
until the Apple logo appears.
4. When the Apple logo appears, release the Menu and Select buttons
and immediately press and hold the Select and the Play/Pause buttons
until the Disk Mode screen appears.
5. Disconnect iPod from the power adapter and connect it to your
computer; the screen on the iPod will change and say "Do not
disconnect"
If you are having difficulty putting an iPod model with a Click Wheel
into Disk Mode, set the iPod on a flat surface. Make sure that the
finger pressing the Select button is not touching the Click Wheel.
Also make sure that you are pressing the Play/Pause button toward the
outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk
Mode, use one finger from one hand to press the Select button, and one
finger from the other hand to press the Play/Pause button."
This of course can also be used in reverse to switch from Hard Drive
mode back to iPod mode.
Yea it should recognize by the computer..let it fully charge and try using it on a different computer and let me know what happen from there...
Remove Itunes completely from your system and reinstall it back..and let me know what happen from there..
I am glad to hear that...once you get a chance dont forget to rate me..
Thank you
Computerrep
SOURCE: ipod nano 4th gen cant sync
HI WE REPAIR ALL OUT OF WARRANTY PDAs,BLACKBERRY ,APPLE IPODS,IPHONES, AND APPLE LAPTOPS SERVING EAST DELHI,WEST DELHI,NORTH DELHI,SOUTH DELHI,NCR,FARIDABAD,GURGAON,NOIDA PLEASE CONTACT US AT JULIAN JOHN : Preet Vihar, Vivek Vihar, Shahdara, Mayur Vihar, Patparganj and Lakshmi Nagar. Pitampura - Rohini - Punjabi Bagh. - JanakPuri - Rajouri Garden - Patel Nagar
SOURCE: ipod nano 4th gen. 8gb SCREEN LOCKED
restore iPod
but unfotunately all your previously synced congs will be lost,,, but its ok then, because you can use your ipod again.
Note: The progress bar may be difficult to see, because the backlight on the iPod display may be off.
I just bought the iPod... it has no charge whatsoever and it doesn't seem like it is getting any even though I can connect and charge my 2nd gen nano and my brother's 3rd gen nano to the same port in my PC. I've even tried using the same chord on my other two nanos, it works on those. I updated iTunes... No change. My only other guess is that it takes a long while to get enough charge in it to recieve any response from my computer that it is there... but it should be recognised anyway shouldn't it?
So let it charge overnight? Coz nothing happens at the moment when I connect it, no "Do not disconnect" or anything. I've had it connected for about an hour so far and still nothing...
I took the iPod in to the reseller, it turns out it is a faulty one. Thanks for your help though. I'll be getting a replacement iPod next week.
