Toys Logo
LARRY ROSS Posted on Dec 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW MANY LIGHTED HOUSES CAN BE HOOKED UP TO A BACHMANN CONTROLLER
I HAVE 13 LIGHTED HOUSES HOOKED TO SAME CONTROLER THEY WILL LIGHT MOMENTARILY AND THEN GO OUT
non sequiter
Level 2:
New Friend:
  • Expert 161 Answers
  • Posted on Apr 12, 2013
non sequiter
Expert
Level 2:
New Friend:
Answers
161
Questions
0
Helped
56080
Points
249
You don't have enough power with a single controller to provide enough power to light all your light houses. You need to figure out the power draw & get a separate power supply.
1helpful
1helpful
2answers
Error codes for 1991 dodge spirit
Turn the key to run then off, back to run, then off, then to run and leave it on. The check engine light will be on and will then go off and then on again according to the codes the engine controler happens to have in it. If the check engine light was on when you stopped the car, then there is at least one code in the controler. The light will blink the codes like this.
Cycle the key three times and leave on on the third time. light on for about 3-4 seconds then goes out for about 2 seconds and then blinks one time and goes out for 3 seconds this is for the no.1. Then the light blinks 3 times and goes out for about 3-4 seconds. You have the code 13. You could have a whole string of codes in the controler memory. It could be something like this. key cycled 3 times, light on for 3-4 seconds, then blinks 1 time, pause, 3 times, longer pause, 2 times ,pause 4 times, longer pause, then 5 times, pause 5 times the goes out.
This is code ; 13,24, 55. code 55 isn't really a code. It just tells you it's the end of any codes the controller has.
If you disconnect the battery and hook it back, you will have code 13 which simply mean 'battery disconnect'. It will errace it's self after several starts if it's not disconnected again. If you cycle the key and you get 55, this means there are no codes recorded at this time.
You will allways get 55 when checking for codes wheather there are fault codes or not. The light on for a few second before the codes start flashing is only a bulb check. Some codes like 13 will not turn the check engine on, but but will leave a code for diagnostic purposes only. If you have the check engine light on and accellerate and the light begains to blink, then the controller is telling you that you have an engine miss and are running the chance of burning out you're catalatic converter if you continue driving. Sometimes its advised to disconnect the battery after you have recorded the codes.
This will erase all codes that are present but were generated by conditions that aren't pertanent to the present condition. and then the codes that come back are the real ones to address.
This link: http://minimopar.knizefamily.net/fault/index.html
Contains the entire list of Chrysler Engine Error Codes.
I bought bachmann spectrum 2-10-2 loco just 2 days back. Its front heels and back wheels gets derails very often. I have many other locomotives and they dont give any problem on same tracks but this loco...
sounds like it's too lightweight! try running with a big blob of plasticine on top, to see of it runs right. if it then works ok you need to fill the internal spaces with lead (ask your local tyre shop for the weights they take off wheels when changing tyres)
1helpful
2answers
Reset defalt settings..... and the screen is telling me to plug in controler and then press the ps3 button and nothing happens
unplug the controller and take a pin and press the small button on the back of the controller to reset. i also had this problem with mine.
I just bought a Lava Glow Wireless Controller for my ps3, but i cant get it to connect to my system. what do i need to do?
With the playstation powered ON plug the USB Receiver in the Console into Input 1#. The Light on the receiver will flash rapidly. On the controller press the menu button. the led on the controller then will flash rapidly, press the menu button again while the LED on the Controler is Flashing. Once you have done this you should get a solid Light on the controler. Now your controler is set.
Why wont my new Bachmann Ho train work. Light comes on, ALL track connections are re-done and great but still no fwd or bkwrd. Anyone???
Had the same problem. The loco would buzz, but no movement. Took the loco & controller to my local hobby shop for testing. Found out my loco was fine, but the controller had shorted out. Swapped it out & it's all good.
2answers
Hooked new brake controler to factory junction box,but controler does not light up,or work,help.
brake controller , as in Towing ? Is it hydraulic over electric? need to know.
Wii controller not working
It sounds like the controler is shot. Did someone let go of this controler in the middle of a game?
Top Bachmann Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Bachmann Toy Expert? Answer questions, earn points and help others
