Computers & Internet Logo
Bob Wehking Posted on Dec 07, 2011
FixCleaner ver 2.0 Email & activation key
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 22, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
455
Points
0
I BOUGHT AUDIO STUDIO IN A BOX FROM BEST BUY. WHERE CAN I FIND THE SERIAL NUMBER TO REGISTER IT?
Duplicate question Deleted. Refresh page to see your question.
Please don't type in all CAPS, it is considered SHOUTING and is harder to read.
According to this the Serial Number is in the manual
Enter the serial number and your email address, then click [Activate & register immediately online].
The serial number is located on the manual included in the product.
SOUND FORGE Audio Studio 12 Ver.12.6 (32bit) ' Sony SG
https://www.sony.com.sg > support > downloads
Jan 24, 2019 - Enter the serial number and your email address, then click [Activate & register immediately online]. The serial number is located on the manual ...
1helpful
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
Front Panel Controls
1.Power Switch:
To turn ON or OFF the power.
2.Power LED:
Lights up to indicate the power is turned ON.
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
2) When OSD menu is in off status, press this button to select scenario
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
used to set the HPos, VPos, Clock and Focus.
5.< / >
Press < or > to select the desired function.Press < or > to change the
settings of the current function.
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
function when OSD is ON.
I keep getting a message that says lookup key active activation context. i cant open anything
did you just up date iexplorer not sure. it is what is sounds like un install the latest version of iexplorer. all the way back to vers 6 then in stall ver 7 and this should fix you problem
1helpful
I want the produtc Key
it should be indiacted in the label, that you had purhased, illegal ver works only for certain trial period, for activation it needs specific key to activate.
Grand Canyon Tech
Grand Canyon Tech
