Nokia 2730 Cell Phone Logo
julius g lagarto Posted on Nov 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
09296371139 my mobile number of nokia2730c-1 i want to connect the internet and GPRS connection
Anonymous
Level 2:
  • Expert 247 Answers
  • Posted on Nov 30, 2011
Anonymous
Expert
Level 2:
Answers
247
Questions
0
Helped
42589
Points
482
GPRS connection needs complete configuration settings from your service provider. Since you are using Smart, you need to call their service hotline for the complete GPRS config settings. There are 2 options for GPRS configuration, manual config settings and OTA (over the air), it will be easier for you to use the OTA, just inform the customer service representative to just send it to you. Then, just save it. For you to test if it is working fine, you need to send an MMS to your own number, once you received the MMS that you send to your own number, that means that its working fine. Possible data rates may apply.
I cannot use my E5 Nokia as a mordem on my laptop. Cellc is a service provider. Iphone cell c help desk several times but no help. i just need step by step pls
To connect internet on your computer with mobile phone,
1. You need a means of connection from your cell phone to your computer or laptop (inferred,bluetooth or data cable), a dialup connection, your proxey settings
steps to connect internet with mobile phone to PC.
Step 1:Take your gprs enabled cell phone and connect it to your computer or laptop using either bluetooth,inferred or a usb cable.
Step 2:Create a dial up connection.Go into yor control panel,then into internet options.Then go to connections and add.Create a dial up connection and when it asks for a phone number type in *99#
Step 3:On your new dialup connection add the same proxy address you have on your gprs in your cell phone.
Step 4:Now on your cpanel there should be something called modem options here you must change the APN to whatever your APN is on yor gprs in your phone.
Step 5:Go to start menu and connect,then connect to your dial up (make sure your cell phone is connected to your computer or laptop)
Step 6:Start your browser (internet exploxer,opera etc) and start surfing the net.
Hope it helped.
Thanks for using fixya...
How to conect noika 6030 to mycomputer
1. You need a means of connection from your cell phone to your computer or laptop (inferred,bluetooth or data cable), a dial up connection, your proxy settings
Step 1:Take your gprs enabled cell phone and connect it to your computer or laptop using either bluetooth,infrared or a usb cable.
Step 2:Create a dial up connection.Go into your control panel,then into internet options.Then go to connections and add.Create a dial up connection and when it asks for a phone number type in *99#
Step 3:On your new dial up connection add the same proxy address you have on your gprs in your cell phone.
Step 4:Now on your c panel there should be something called modem options here you must change the APN to whatever your APN is on your gprs in your phone.
Step 6:Start your browser (internet explorer,opera etc) and start surfing the net.
Hope it helped.
How to activate my mms? globe prepaid
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service.
or
This tutorial will help you setup your mobile phone and activate/configure GPRS, 3G and MMS features for Globe Telecoms.
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Internet Settings
6. Create New Profile
Connect Using: MyGlobe GPRS
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Proxy Address: 203.177.042.214
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
Address: http://www.globe.com.ph/globe.asp
12. Save Changes
MyGlobe Internet Settings
3. Create New Account. GPRS / PS Data
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
1. Go to Menu>Choose Settings>Connectivity
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
3helpful
2answers
How can i net connect from my samsung mobile s5230 to my computer
For using your mobile as a modem to connect to internet from your PC via mobile phone, please follow the below steps:
1. Ensure that you have activated the proper GPRS internet subscription and you should be able to browse in your mobile phone. If not, please contact you network operator's customer care to activate GPRS in yourmobile.
2. You should have proper settings received from your operator and saved in your mobile phone.
3. Install all the drivers and softwares provided in the driver cd which came along with your mobile phone.
4. Connect your mobile phone to your system. If prompted for any mode of connection, choose the connection type as pc suite mode / pc mode, etc but not the mass storage or pen drive like mode.
5. Now use the new connection wizard from start -> programs -> accessories -> communication- > new connection wizard.
6. In the wizard select connect to internet -> dial up connection -> configure manually -> select your mobile phone modem -> provide no username and password.
the dial number would be like *99***1# (IN CASE OF airtel). If you are with any other mobiel operator, please contact you network operator to know abt the dial number.
7.once the wizard is done, then a new connection willbe created in control panel -> network connections window. Double click it to connect.
I hope this information is helpful to you.
Please provide your comments and ratings.
Thanks
2answers
I am unable to connect using gprs on my Q3 micromax mobile setting for aircel connection.
Following are the steps to use internet on ur micromax Q3 handset:
Step 1. : Open the Menu nad then go to services option.
Step 2. :Click on that and move to Data account and then Click ok.
Step 3. :Select the GPRS & then click OK.
Step 4. :Go to the empty account and then click on Edit.
Step 5. :Write 'PI' (means Pockit Internet) on the Account Name.
Step 6. :Write APN = aircelgprs and leave the username and Password as blank. Auth. type will be Normal.
Step 7. :Press Back Button three times, u will be on the services menu.
Step 8. :click on the WAP and select the sim number u want to access the internet and press OK.
Step 9. :now u can access the internet.
Mar 06, 2010 • Cell Phones
5helpful
2answers
I have tmobile and i can't connect to the internet on my phone
well i tryed doing this n it worked but its only 4 t-mobile so.. if u dont got t-mobile i dont think i can help >.<
These settings are for T-Mobile
Tmobile Setting
WAP
1- Main Menu click on Entertainment then click on Services
2- Click on Data Account–> click on GPRS
3- Choose any account–> click on Edit
1- Account Name
TMOBILE
2- APN
wap.voicestream.com
3- User Name
leave it blank
4- password
leave it blank
5- Auth. Type
Normal
CLICK ON DONE AND SAVE IT
CLICK ON BACK TWICE IT WILL TAKE YOU BACK TO SERVICES
5-Click on WAP –> click Settings–> click Edit Profile.
6- Choose any one on list then press ok–>Edit Profile
1- Rename Profile->(name it anything or u can name it T-mobile GPRS)
2-Homepage–> http://wap.myvoicestream.com
3-Data Account–>Select–>click on Gprs–> you will see the one we named earlier TMOBILE, select it and press OK
4- Connection Type
HTTP
5.Proxy serv address: 216.155.165.050
6.Proxy port number: 8080
7. Username
leave it blank
8. Password
leave it blank
CLICK DONE AND SAVE IT—>CLICK ACTIVATE PROFILE AND SAVE
SMS
1- Click on thee envelope icon it will take you to Messages
CLICK ON SMS
1- Message settings–> click in Profile Setting
2- Click edit on any profile name it T-mobile that will be line No. 1 in No.2 type +12063130004
MMS
1-Message Settings–>click Server Profile
2-Click on any 1–> click on Edit Profile
1- Rename profile
T-mobile MMS
2- Homepage
http://216.155.174.84/servlets/mms
3-Data Account
click on GPRS–> choose Tmobile–> press OK
4- Connection Type
HTTP
7.Username: leave it blank
8.Password: leave it blank
CLICK ON DONE –> SAVE–>ACTIVATE PROFILE
Jul 17, 2009 • Cell Phones
1helpful
3answers
GPRS not subscribed
Your Prepaid doesn't have Data Service... GPRS is the 3g network ... so if you dont have a Data Plan... or data service on your phone you can't go on the internet... and i bet if you could with a prepaid card... it would DRAIN your $$
GPRS activition for free
fooling Airtel - FREE gprs, mms, airtel live, more  lets start from free gprs via airtel live  pls note this trick works only on mobile with multi channel support  it was not found by me .
u need a PC or a Laptop and the required connectivity tools ,ie.,  Serial/USB cable OR Infrared Device OR Bluetooth dongle
1) Activate Airtel Live! ( It's FREE so no probs)
2) Create 1 Airtel gprs data accounts and select the  FIRST as the active profile.  CODE  Under DATA COMM  ~~~~~~~~~~~~  GATEWAY : 100.1.200.99  APN : airtelfun.com
USERNAME : blank
PASSWORD : blank
PASS REQ : OFF
ALLOW CALLS : AUTOMATIC
IPADDRESS :100.1.200.99
DNSADDRESS 1 : 202.56.230.5  DNSADDRESS 2 : 202.56.240.5
DATA COMP : OFF
HEADER COMP : OFF
Under INTERNET PROFILES  ~~~~~~~~~~~~~~~~
INTERNET MODE : HTTP or WAP (both works)
USE PROXY : YES
IP ADDRESS : 100.1.200.99
PORT : 8080
USERNAME :
PASSWORD :
3) Connect your mobile to the PC (or Laptop) and install the driver for  your mobile's modem.
4) Create a new dial-up connection using the NEW CONNECTION  WIZARD as follows
Connecting Device : Your mobile's modem  ISP Name : Airtel (or anything you like)  Phone Number : *99***1#  Username and Password : blank
5) Configure your browser and download manager to use the proxy  100.1.200.99 and port 8080.( My advice is to use Opera since you  can browse both wap and regular websites)
6) Connect to the dial-up account. You will be connected at 115.2  kbps (NOTE* 115.2 KBPS IS A SPEED BETWEEN UR PC AND PHONE ).
7) Pick up your mobile and try to access any site. You will get "Access  Denied."(except for Airtel Live!). IT DOES NOT MATTER.  Keep the mobile down.
8 ) On the PC ( or Laptop) open your browser, enter any address ,  press ENTER and.WAIT
9) After a few seconds the page will start to load and you have the  WHOLE internet at your disposal.
[quote] pls Note If u are getting any error wile dialing a dial up connection than go to  Control panel>> Phone and modem>>>select modem and click on its properties >>advanced
cntd  and enter the following initialization commands  CODEAT+CGDCONT=1, "IP","airtelfun.com","",0,0  and click on ok now connect to gprs it will be connected without any error
to improve the speed  go to run and type  ping -t 100.1.200.99  and pres enter  and minimize the window it will improve the speed delete
airtel live @ free  airtel live @ free
point ur browser to http://10.2.0.92/cmtairtel/content/
2helpful
Gprs not connecting
i) if you want internet connection on your htc mobile try to contact airtel customer care they will provide full assistance. they will ask you to send an message to certain number and then u will get internet settings on to your htc mobile and from then you can start using internet on phone and as well you can connect your computer to mobile and start surfing internet on your computer also....
ii) dont mess it lift you mobile and dail to your airtel customer care ..............
Thanking you
M. Sridhar
23helpful
7answers
Gprs settings
For BSNL South prepaid or post paid use following settings:
Start/ Settings/ Connections /GPRS
Connects to : Internet
Access point: gprssouth.cellone.in
Leave other items blank.
Start/ Settings/ Connections /Proxy
Donot creat any proxy
You donot require any thing else. GPRS will work on your mobile and also in Internet share. Internet share works with cable and bluetooth. Browse on mobile or laptop !!!
9448834529
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
