Photography Logo
lucy Posted on Nov 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't tune my technika TV since the digital switch over it's only DTV that i can't get can you help me?
I need dtv as it has most of the mail chanels on it can you help?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Linhof Master 102,366 Answers
  • Posted on Jan 18, 2012
Linhof Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444598
Points
622693
You directed this question at me, but unfortunately I am not able to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
You might also want to consider posting this question in an area other than "Film Cameras."
Thank you for using FixYa.
I have a 32 inch Element TV model ELEFW328 that will not pick up DTV channels how do I get DTV signal on my TV
Did you go into settings and tune into DTV settings, did the TV look for digital signals ?, if not check out the aerial.
2helpful
I cannot retune my samsung tv- model no LE37C53CF1W- COULD YOU ADVISE HOW TO RETUNE, mANY THANKS, Jim Lauder
Hi,Does the icon look like a large satellite dish?
Make sure your TV is on "TV" and not "DTV" before retuning.
To re-tune analogue channels:
I have a Samsung TV and that icon is not accessible from the menu if i am watching the tv on the digital option of my remote. You have to switch your tv to the "tv" option on your remote and you will be able to access the icon from your menu.
(on your remote, you should have a button with TV/DTV on it)
To re-tune analogue channels, if you want to re-tune digital channels, then look for the "D MENU" button on your remote. Press this then scroll down to the icon that looks like a large satellite and then on "Auto Store" This will re-tune your digital channels :0)
Take care and hope it helped.
Papajomz
If your TV is not in Digital it won't give you the tuning option.
Select DTV from ythe on screen menu, (like scart 1 scart 2 etc). When you have found DTV select it and then press menu for tuning.
Hope that helps.
2helpful
2answers
Following the beginning of digital switchover, pressing the menu button only comes up with 'picture quality' and is unable to access 'installation'.
Select DTV from the on screen menu, (like scart 1 scart 2 etc). When you have found DTV select it and then press menu for tuning.
Hope that helps.
1helpful
I recently bought Technika LCD26-209V,I installed
I have a technika lcd26-209v. I want to fit 2 external speakers. Can I just plug them into the TV or do I need to get an amplifier. I just want to broadcast the sound from the tv not play discs etc
My DTV stopped working giving a blank screen
It may just need to be Re-tuned.
What I would suggest you do is make sure that you are on a DTV channel on your Tv. then with your Pioneer remote press the menu button and then set it away on a Auto tune.
You must have it on a DTV channel first before try to tune as if you mistakenly have it on TV (terrestrail channel) It will only Auto tune that and not your freeview.
Hope you get it sorted.
Cheers Little Dish Fitter
1helpful
Wont tune in dtv
Does it have a digital tuner? If not, you need a set-top box. If that's covered, you may need an antenna.
After the DTV switch, should I be placing the cable cord into the dtv output to receive all the DTV channels? Protron PLTV 3250 is the set I have and it doesn't seem to get the DTV channels like my other...
Your question is confusing. If you have cable, you don't need a DTV converter box.
If your cable company has switched to digital cable, they will provide you a box, and the cable should go from the wall into the box, then into your TV.
If you don't have cable but instead rely on an antenna, then the wire will go from the antenna into the DTV box, then from the DTV box into the back of the TV. If you're using a regular coaxial cable to go from the DTV box into the television, the TV should be set to channel 3. If you're using the red-yellow-white RCA wires between the DTV box and the television, the TV must be tuned to "Aux," "Line In," "Input Select," or whatever it's labeled on your particular set.
1helpful
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
2answers
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Top Linhof Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Linhof Photography Expert? Answer questions, earn points and help others
