Refrigerators Logo
A
Anonymous Posted on Nov 23, 2011
We have a two door refrigerator in our RV, there appears to be a very bad smell like rotten eggs could this be coming from the fridge even when its turned off clean and empty
Level 3:
  • Master 17,130 Answers
  • Posted on Nov 23, 2011
Master
Level 3:
Answers
17130
Questions
0
Helped
3635667
Points
52372
Please find tips on how to reduce your smell within the fridge.
click this link:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/1434/how-to-fix-a-smelly-fridge.html
When opening my fridge it smells like gas is this bad
If the fridge runs on LPG it can mean that there is a gas leak. Which can be bad because it can explode. LPG smells like rotten eggs. So if that is the smell have the fridge checked out.
Smells like rotten eggs
it is happen to old engine because the oil that escape from the engine(engine cover near the exhaust) when it is got hot it sends bad smell but after how many minutes if it already dried up because of heat it will gone (like frying using the used cooking oil in pan there is a different smell).
Truck is giving off a rotten egg smell !
rotting egg smell is associated with your cat converter going bad
1helpful
Whirlpool refrigerator has an awful smell coming from the bottom. We cleaned the drip pan the smell went away, the next day the motor turned on and the smell came back. Can it be the motor?
If the fridge is failing to keep the freezer as cold as it was, it is only a matter of time (hours or maybe a day) before it stops cooling completely.
If you smell sulfur or rotten eggs, and cooling inside is diminished, it is very likely that the refrigerant has escaped due to line chafing, rupture or compressor failure. This is not the type of failure your want. Many times, this repair costs many hundreds of dollars to repair and isn't worth the expense. Other times, a line can be repaired after cleaning & evacuation. A service port is installed to allow a new refrigerant charge to be introduced to the fridge.
The only way to know for sure is to have it checked by a licensed refrigeration mechanic or fridge repair technician.
1helpful
My 2002 Pontiac GP V6 smells like rotten eggs from the exhaust
The rotten egg smell if it is coming from the exhaust is a very good sign that you catalytic converter has failed or is failing. but a bad or battery that is being overcharged can also make a rotten egg like smell.
2helpful
Our rv has a dometic rm2600 fridge that smells of ammonia inside and has a little bit of yellow residue in behind service panel. is the fridge wrecked or is it worth repairing. the rv is 27 years old.
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
The water and ice in our refrig tastes and smells like rotten eggs. our water from the tap does not. even with a filter it still smells that way. It was perfectly fine for the first 4 months we had it....
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
3helpful
2answers
Bosch classixx fridge freezer - smell coming from fridge. Can only smell when door opened.
bad eggs smell coming from behind Bosch fridge freezer. There is no bad food in fridge. Any comments appreciated. Linda
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
