Master
- Posted on Nov 15, 2011
Re: Water pump/timing belt on 02 volvo s60 turbo diagram
5-Cylinder Engines
Before servicing the vehicle, refer to the Precautions Section.
Remove or disconnect the following:
Negative battery cable
Engine stabilizer brace
Servo reservoir
Expansion tank
Accessory drive belt
Front timing belt cover
Right front wheel
Inner fender liner
Turn the crankshaft clockwise until the markings on the crankshaft and camshaft pulley correspond.
Turn the crankshaft a further 1/4 turn clockwise and then back again until the markings correspond.
Remove the upper timing belt cover.
Slacken off the belt tensioner center bolt slightly.
Hold the center bolt still and turn the eccentric on the tensioner clockwise to 10 o'clock.
Remove the vibration damper using Volvo counterhold 999 5433 or equivalent.
Remove the camshaft belt.
To install:
Turn all the pulleys listening for bearing noise. Check to see
that the contact surfaces are clean and smooth. If the tensioner pulley
lever or idler is seized, replace it.
If replacing with a new idler pulley, tighten to 18 ft. lbs. (24 Nm).
If replacing tension pulley, screw into place using the center
bolt by hand. Ensure that the tensioner fork is centered over the
cylinder block rib. Ensure that the Allen hole on the eccentric is at
"10 o'clock".
Install the camshaft belt over pulley wheel on the crankshaft.
Install the vibration damper and tighten the center nut to 133 ft. lbs. (180 Nm).
Install the timing belt in the following order:
Around the crankshaft sprocket.
Around the right idler pulley
Around the camshaft sprockets
Around the water pump
Onto the tensioner pulley
Carefully turn the crankshaft clockwise until the timing belt is
tensioned. The belt must be tensioned between the intake camshaft
pulley, the idler pulley and the crankshaft
Hold the belt tensioner center bolt secure. Turn the belt
tensioner eccentric counter-clockwise until the tensioner indicator
passes the marked position.
Then turn the belt tensioner eccentric back so that the indicator
reaches the marked position in the center of the window and tighten the
center bolt to 15 ft. lbs. (20 Nm).
Press the belt to check that the indicator on the tensioner moves easily.
Install or connect the following:
Front timing belt cover and tighten to 9 ft. lbs. (12 Nm)
Upper timing belt cover
Servo reservoir
Expansion tank
Engine stabilizer brace. Tighten the bolts at the suspension
turrets to 37 ft. lbs. (50 Nm). Tighten the engine bracket bolt to 59
ft. lbs. (80 Nm).
Inner fender liner
Front wheel
Fig. Timing mark alignment
Fig. Belt tensionerwater pump/timing belt on 02 volvo s60 turbo diagr - 11_15_2011_12_37_19_am.gif
Belt tensioner
Fig. Timing belt installed
Fig. Tension indicato
Tension indicator at different temperatures
