HOW DO YOU REMOVE THE MIDDLE SEAT BELT ON THE PASSENGER SIDE? MY IS BROKEN AND I WANT TO REPLACE HOW DO I REPLACE IT.
It is bolted to the seat frame you have to remove the bolt and nut. it's a torx bit size #60 and a metric wrench size 15 mm that you will need. please rate the solution...thanks
if there are no screws there are clips that hold the panel in place. these clips are metal and the plastic panel has like molded prongs the clip into them so you have to pry the plastic panel away but take your time and use even pressure to remove the panel
if there are no screws then yes you have to remove it the same way. I have a town and country and they are almost the same.
thanks for the help but the problem that i am having is removing the side pnael in the rear where the cup holder is located to get to the belt on the inside of the frame. how would you remove the back panel on the passenger side to get to the inside of the belt to remove all of it?
is this the same way that you would remove the top pieced of the same panel? the caravan that we have has two peices one that has clips that hold the bottom and the other that goes where the storage would be. that is the ones that i can not figure out how to remove?
