SOURCE: Pitco 35C+ fryer. Pilot lights fine; main burner
Its a simple design. If the thermophile does the work of powering the fryer control. Do you have a good pilot flame? If the pilot flame ain't good enough then the millivolts won't be enough to operate the solenoid on the gas valve. Most folks replace both the pilot and thermophile on these fryers since the grease makes such a mess of everything. If the pilot generator is fine then the gas valve is next.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: 13 year old pitco frialator fryer pilot wont stay
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
